liquidiq Posted November 3, 2004 Share Posted November 3, 2004 Is there any way to aim our headlights on the '05 Legacys? I think mine might be a hair high. Link to comment Share on other sites More sharing options...
rkkwan Posted November 6, 2004 Share Posted November 6, 2004 Yes, there's a screw in the headlight assembly to adjust the aiming height. It's located between the low- and high-beams, lower than the centerline, with a white plastic wheel that you can see its teeth. According to the service manual, if you park your car 10ft (3m) from a wall, the lower-cutoff should be 619mm from the ground for the sedan, 616mm for the wagon, and 686mm for Outback models. Link to comment Share on other sites More sharing options...
