RS22b Posted March 23, 2007 Share Posted March 23, 2007 OK im sure that this has been covered but who has done it ? Is it possible ? What do you need to do ? japanparts sells this: http://japanparts.com/images/ImageFromDB.php?base=1&no=3590 Im pretty sure that it is only the plastics and not the climate control included, but i could be totally wrong. I know that i could just buy a 07 radio and be done with it, but to tell you the truth the stock radios that they sell here in the US are really garbage as far as the processor dishing out sound to the speakers. It just isnt clean enough for me. So i wanna put a Premier head unit in the car with the stock climate controls that come with the car. anyone ? _billy PS: japanparts part# is 107-209-006 Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted March 23, 2007 Share Posted March 23, 2007 there is nothing that will work thus far....climate controls are built into the radio, thus no separating them This has been attempted and its far too complicated. Certain people are working on a solution but the details and progress are unknown [EDIT:] apparently it was successfully done...check post #4 below. This is news to me Link to comment Share on other sites More sharing options...
RS22b Posted March 23, 2007 Author Share Posted March 23, 2007 cool thanks for the info. The ppl that are working on it, do you know if they got down to trying to seperate the radio and the CC? I think once you pull the case apart you can probably seperate the two. i really need to sit down and look this over myself before i order that part# from them. Obvoiusly that is the easy part. Although if that piece that i can buy from them does come with climate control then its just a matter of pinning out the connectors. Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted March 23, 2007 Share Posted March 23, 2007 heres some reading for ya: http://legacygt.com/forums/showthread.php?t=55347 http://legacygt.com/forums/showthread.php?t=46539 And a successful install: http://legacygt.com/forums/showthread.php?t=48531 Link to comment Share on other sites More sharing options...
fweasel Posted March 23, 2007 Share Posted March 23, 2007 And a successful install: http://legacygt.com/forums/showthread.php?t=48531 Clarification, successfull custom fabrication and separation of original USDM HVAC/radio controls... not the JDM piece. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted March 24, 2007 Share Posted March 24, 2007 Clarification, successfull custom fabrication and separation of original USDM HVAC/radio controls... not the JDM piece. thanks...didnt see that Link to comment Share on other sites More sharing options...
RS22b Posted March 24, 2007 Author Share Posted March 24, 2007 great thanks for the info! Link to comment Share on other sites More sharing options...
croll326 Posted March 27, 2007 Share Posted March 27, 2007 http://www.rallitek.com/dodincopa.html http://www.rallitek.com/inparebr.html here is an idea. use the cubby and relocate the clock. Link to comment Share on other sites More sharing options...
fweasel Posted March 27, 2007 Share Posted March 27, 2007 http://www.rallitek.com/dodincopa.html http://www.rallitek.com/inparebr.html here is an idea. use the cubby and relocate the clock. Been there, done that. The issue at hand is trying to remove the OEM radio and putting a DD head unit in its place. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
RS22b Posted March 28, 2007 Author Share Posted March 28, 2007 thanks for the heads up on that stuff. I was goin to do that with my XT but ended up getting a Spec B. Im really looking to put in a single DIN head unit and a pocket - which is still pretty much a DD. Link to comment Share on other sites More sharing options...
RS22b Posted April 11, 2007 Author Share Posted April 11, 2007 any update on this yet? Link to comment Share on other sites More sharing options...
RedHotLama Posted May 29, 2007 Share Posted May 29, 2007 thanks for the heads up on that stuff. I was goin to do that with my XT but ended up getting a Spec B. Im really looking to put in a single DIN head unit and a pocket - which is still pretty much a DD. This is kind of my plan for when i get mine. Link to comment Share on other sites More sharing options...
keysersoze Posted June 10, 2007 Share Posted June 10, 2007 http://www.rallitek.com/dodincopa.html http://www.rallitek.com/inparebr.html here is an idea. use the cubby and relocate the clock. Anyone try this double din cubby replacement on an 07 or 08 yet? Anyone even know if it will fit? Link to comment Share on other sites More sharing options...
