klaus Posted March 17, 2007 Share Posted March 17, 2007 Hi, After about 500 mile drive a couple of weekends ago, the air conditioning started to make a quiet hissing sound when on. It sounds similar to a vacuum when you pull the pipe off and it sucks air at the wrong place (much quieter obviously). If I switch the AC off, the noise is gone. Any ideas? I plan to take it to the service next week, but just wanted to get your opinion before I go there. Thanks, Klaus. Link to comment Share on other sites More sharing options...
klaus Posted March 24, 2007 Author Share Posted March 24, 2007 Hi, For all those that experience the same symptoms: there was no freon. The dealership couldn't find a hole or anything so they put dye in it and now we'll see what happens in the future. If it repeats, they'll investigate. Klaus. Link to comment Share on other sites More sharing options...
unstablementaly Posted March 24, 2007 Share Posted March 24, 2007 if it lost it's refrigerant charge there is a leak. unless some jackass forgot to charge it at the factory! the dye is to find the leak. run the AC daily for say, 36 hours total operation time. then bring it back for them to find the leak with the blacklight. the dye is flourescent and comes out with the oil that is also leaked with the refrigerant charge. my vBGarage Link to comment Share on other sites More sharing options...
icehousewvu Posted March 30, 2007 Share Posted March 30, 2007 Same exact problem here... Weds was the first really warm day of the year and I had nothing but warm air blowing when I tried to use my A/C. I also have the hissing sound this is b/s as my car is a little over a year old but of course its out of warranty as it has 45K miles. Dealer claims its gonna cost $89.95 to have it "Evacuate" and recharged. Link to comment Share on other sites More sharing options...
icehousewvu Posted March 30, 2007 Share Posted March 30, 2007 I just wanted to add that after doing some searching I just hope like hell its not my condensor. Link to comment Share on other sites More sharing options...
unstablementaly Posted March 30, 2007 Share Posted March 30, 2007 rock thru the condensor coil FTMFL. yeah that would suck. shame it's not copper otherwise i'd say braze it! you could always pull the coil and pressure test it for the leak and see if someone can weld the aluminum for you. my vBGarage Link to comment Share on other sites More sharing options...
