The Don Posted March 7, 2007 Share Posted March 7, 2007 So i've now replaced all 4 tires on my car and 2 rims...my car is 14 months old...talk about bad luck with wheels... back story-got a blow out from a pot hole on rt. 80(front left)...bubble in another tire 2 months later(back left) now last week i hit a big a$$ flippin rock bent 2 rims and blew the tires(rt 17 couldnt avoid it or id hit the guy to my right or hit the wall)...thank god no other damage to the car...(right side of car) I get the car back and i notice there seems to be gas coming out of the gas tank...its on the side of the car in streeks...and inside the tanks door is COVErd with brown gook aka gas...im guessing they rotated the tires cuz the new rims are on the back wheels...and my question is do i need an alignment..i turn the wheel at an angle and it wont go back it just stays there while driving???and it doesnt feel tight the wheel is very loose...Most of you are gunna say my drivin this an that.. but when i drive spirited..nothing happends when i obey the laws speed limit ect.. this happends to me... Link to comment Share on other sites More sharing options...
Bdubs Posted March 8, 2007 Share Posted March 8, 2007 Yeah, I'd most certainly get a 4 wheel alignment just to be safe. Link to comment Share on other sites More sharing options...
Flanders Posted March 8, 2007 Share Posted March 8, 2007 You may have busted more than you know. Look into replacing the steering rack bushings and get an alignment. Link to comment Share on other sites More sharing options...
The Don Posted March 8, 2007 Author Share Posted March 8, 2007 It came from the dealership...said they did 27 point check...maybe the gas spilled out from it being flat bedded..and the guy didnt close it tight...only thing i can think of...but wouldnt a dealership say hey u need an alignment and why would they switch the wheels around anyway? Link to comment Share on other sites More sharing options...
Scotty Posted March 8, 2007 Share Posted March 8, 2007 Duh! So keep driving spirited. Gas shouldn't be leaking out from being flat bedded. Link to comment Share on other sites More sharing options...
forestir Posted March 8, 2007 Share Posted March 8, 2007 Gas leaking should be easy for someone to isolate and fix. Shouldn't ignore that. +1 that something's wrong with your alignment. Probably not enough caster due to bent suspension part. Link to comment Share on other sites More sharing options...
The Don Posted March 8, 2007 Author Share Posted March 8, 2007 thanks for all the help Link to comment Share on other sites More sharing options...
godwhomismike Posted March 8, 2007 Share Posted March 8, 2007 Check tire pressures (35psi in front and 33 psi in rear). Also, get a wheel alignment done. What tires are you using? . Link to comment Share on other sites More sharing options...
The Don Posted March 8, 2007 Author Share Posted March 8, 2007 the stock son of a B's Link to comment Share on other sites More sharing options...
