C.S. Posted February 20, 2007 Share Posted February 20, 2007 After changing my break for Brembo, i had this code err 55. Help please Link to comment Share on other sites More sharing options...
Xenonk Posted February 20, 2007 Share Posted February 20, 2007 check your hubs, do you have something in the way of the speed sensors? try clearing your ECU by unplugging the battery, pump the brakes, and then hook the battery back up. Keefe Link to comment Share on other sites More sharing options...
C.S. Posted February 20, 2007 Author Share Posted February 20, 2007 thanks, i'll check that. First, i'll clear my ECU.........but i have an AP, is there a special procedure to not lose my program? Link to comment Share on other sites More sharing options...
robinlsb Posted February 20, 2007 Share Posted February 20, 2007 There are speed sensors on all four wheels. Either you bunged a sensor or a wire is loose. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
