moviemadness Posted February 14, 2007 Share Posted February 14, 2007 has anyone been through this? how do you take out the ECU? can someone direct me to a link? If I just go to the dealer, they would definitely void my warranty, right? Link to comment Share on other sites More sharing options...
antny Posted February 14, 2007 Share Posted February 14, 2007 The ECU is under the passenger floor board. If you pull the carpet up you should see the portective metal cover. If it is anything Like a WRX which it should be. unscrew the nuts off the covering and then the ecu should have 2-3 nuts holding it down also. Unplug all the harnesses and it should come right out. Link to comment Share on other sites More sharing options...
scoobydrew Posted February 14, 2007 Share Posted February 14, 2007 If you're talking about a stock re-flash, I was told by a dealership that they are able to only flash updates, that they have to send it away for full stock re-flash. ProTUNED by RaminiSports Link to comment Share on other sites More sharing options...
one69chev Posted February 14, 2007 Share Posted February 14, 2007 most dealer re-flashes will update certain parameters---air/fuel mixes etc.... any performance shops on the forum re-flash?? Link to comment Share on other sites More sharing options...
moviemadness Posted February 14, 2007 Author Share Posted February 14, 2007 cobb called it benchflashing, since the corrupt AP screwed up my ecu data, they have to benchflash it, which I have no idea what that means.. Link to comment Share on other sites More sharing options...
Jon in CT Posted February 14, 2007 Share Posted February 14, 2007 Benchflashing means you take the ECU out of the car and put it on a workbench. Then you open it up and connect a cable from a PC directly to the circuit board and reflash it using the same method the factory used. Link to comment Share on other sites More sharing options...
moviemadness Posted February 14, 2007 Author Share Posted February 14, 2007 yes I understand that. well it turns out I don't need it anymore the AP suddenly decided to work again, so i'm back to the stock map, and the friggin car now starts.. thank god. Link to comment Share on other sites More sharing options...
