BigInALegacy Posted February 3, 2009 Share Posted February 3, 2009 me too, might today cuz the clunking is getting to me... Link to comment Share on other sites More sharing options...
bosco Posted February 3, 2009 Share Posted February 3, 2009 my Cusco bars and ES bushings are going on two years in all weather conditions with no issues. carry on. Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Guest Posted February 3, 2009 Share Posted February 3, 2009 ES bushings? Link to comment Share on other sites More sharing options...
bosco Posted February 3, 2009 Share Posted February 3, 2009 ES bushings? http://www.energysuspension.com/ Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
ShadowImg Posted February 3, 2009 Share Posted February 3, 2009 ^ Autozone here actually stocks these on the shelf even. I was surprised to see it after reading about them. Only thing I'm not sure of is how well the straps fit our cars. I recall seeing some threads saying you need to trim down the straps because they're way too big. Link to comment Share on other sites More sharing options...
bosco Posted February 3, 2009 Share Posted February 3, 2009 ^ Autozone here actually stocks these on the shelf even. I was surprised to see it after reading about them. Only thing I'm not sure of is how well the straps fit our cars. I recall seeing some threads saying you need to trim down the straps because they're way too big. rear ones bolt right on the fronts need the front edge of the straps need appox. 3/8" iirc ground off or cut off at a slight angle to clear other than that no problems. grease well. Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
ShadowImg Posted February 3, 2009 Share Posted February 3, 2009 What kind of grease do you use? I need to grease my cobb bushings, and actually just sent them an email they haven't replied to yet to ask what type of grease I should use. The stuff they sent in the clear containers didn't have any indication as to what it actually was. Link to comment Share on other sites More sharing options...
bosco Posted February 3, 2009 Share Posted February 3, 2009 What kind of grease do you use? I need to grease my cobb bushings, and actually just sent them an email they haven't replied to yet to ask what type of grease I should use. The stuff they sent in the clear containers didn't have any indication as to what it actually was. i used the grease that came with the set i would guess any lithium based or water proof white grease should work Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
ShadowImg Posted February 3, 2009 Share Posted February 3, 2009 Yeah, I picked up white lithium grease, which is most likely what I will use if I don't hear back from them. From research I've done I found that apparently petroleum based grease (like lithium grease) will degrade urethane over time so you're supposed to use synthetic/non petroleum based stuff. Only problem is nobody seems to know exactly what that is (maybe not a product you can buy off the shelf at all) A common recommendation is "Blue Marine Grease" to give better life. I may hit up a boating shop and see what that runs at some point. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted February 4, 2009 Share Posted February 4, 2009 Amsoil makes a great synthetic grease. I used it on my sway bar bushings and when I checked them after a year, then two, they were still fine. All poly bushings. I use it wherever I need grease. I've had the same tube for many years. Link to comment Share on other sites More sharing options...
BigInALegacy Posted February 4, 2009 Share Posted February 4, 2009 just put the ones I got from ebay on. they were the energy suspension, 21mm. went on easy, no more clunking from my quick test drive. you can definitely tell the difference between the ES and the other ones. Link to comment Share on other sites More sharing options...
MDork Posted February 9, 2009 Share Posted February 9, 2009 just ordered these. thanks guys. Link to comment Share on other sites More sharing options...
MDork Posted February 9, 2009 Share Posted February 9, 2009 OT but anyone have an opinion on AVO vs Cobb rear bracket reinforcement? Or are you guys just going naked with the Cuscos? Link to comment Share on other sites More sharing options...
bosco Posted February 9, 2009 Share Posted February 9, 2009 OT but anyone have an opinion on AVO vs Cobb rear bracket reinforcement? Or are you guys just going naked with the Cuscos? i have the AVO bracket as insurance so far nothing bent but then again i don't track my car. Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2009 Share Posted February 9, 2009 I like AVO brackets better but remember to get longer bolts for the bar's brackets. Link to comment Share on other sites More sharing options...
MDork Posted February 10, 2009 Share Posted February 10, 2009 cool thanks...surprised they don't come with bolts.. Link to comment Share on other sites More sharing options...
BigInALegacy Posted February 10, 2009 Share Posted February 10, 2009 <~~ AVO Bracket as well Link to comment Share on other sites More sharing options...
car_cursed Posted May 8, 2012 Share Posted May 8, 2012 Anyone know if these will fit a stock front 06 LGT sway bar without issues? I want greasable but I the closest energy suspension greasable are 20.5mm. [ame=http://www.amazon.com/gp/product/B0038762PY/ref=ox_sc_act_title_1?ie=UTF8&m=A2RF7IAU8285XR]Amazon.com: Prothane 19-1164-BL Black 21 mm Universal Greasable Sway Bar Bushing fits A Style Bracket: Automotive[/ame] Link to comment Share on other sites More sharing options...
