jmn69 Posted February 11, 2007 Share Posted February 11, 2007 I just put these on with snow tires. Funny thing is that they stick out of the wheel well slightly more than the stock wheels and rims. looks like a sublte spacer effect. I paid 92 bucks a piece for these. Will this adversely affect my steering, handling or suspension? I think the guy told me they were 48 mm offset but I.m not sure. Please advise if I'm fugged. Check out the pics. Car has a lot of salt on it. http://www.kodakgallery.com/ShareLandingSignin.jsp?Uc=euvsq4k.chnvy0m4&Uy=h1zyvb&Upost_signin=Slideshow.jsp%3Fmode%3Dfromshare&Ux=0 Link to comment Share on other sites More sharing options...
bosco Posted February 11, 2007 Share Posted February 11, 2007 welcome to the forum. shouldn't be a problem btw bosco always wanted to do that Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 11, 2007 Share Posted February 11, 2007 I'm running ASA JH3 from tirerack with my winter tires. I selected the 2004 STi fitment which is 17x7.5 +45 offset. The 2005 LGT fitment was originally 17x7.5 +48 offset. I wanted to make sure it would clear the Brembo's if I ever got them. If you take the rim off, the size will be cast into the wheel on the back. The offset is the number next to ET. For example ET45 is 45mm offset. You're fine. I think it looks more aggressive with the wheels almost flush with the fender. <--- Those are my summer rims. 18x8.5 SSR Comp +48 offset. Link to comment Share on other sites More sharing options...
fatbastard Posted February 11, 2007 Share Posted February 11, 2007 I got the same ones....your fine. I did notice that the feel of the car was a little different but nothing crazy. I don't know a whole lot about suspension but I would say the cars turn in felt a little crisper, but I don't know if that is because the wheel has been moved out or if it is due to teh wider rim section. I do notice bumps a bit more than before which could be due to the heavier weight over stock or it could jus be a sidewall difference. I am sure you'll get better info from Xenonk Link to comment Share on other sites More sharing options...
jmn69 Posted February 12, 2007 Author Share Posted February 12, 2007 PICS!! http://www.kodakgallery.com/ShareLandingSignin.jsp?Uc=euvsq4k.chnvy0m4&Uy=h1zyvb&Upost_signin=Slideshow.jsp%3Fmode%3Dfromshare&Ux=0 Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 12, 2007 Share Posted February 12, 2007 That will look better once you lower it off the jacks. Link to comment Share on other sites More sharing options...
