Alex C Posted February 6, 2007 Share Posted February 6, 2007 I have an 06 Legacy SE. 1: Does anyone know how to replace the light in the mini storage compartment above the stereo? 2: Is there a mod or method to make my doors auto lock after the car is moving? 3: The manual specifies 7500 mile oil changes? should I just stick with 3k? 4: Apperently the auto off interior lights has been disabled, how to I re-enable it? 5: Where is the best place to go in the Portland area to get 3 very small dings removed? Thanks, Alex Link to comment Share on other sites More sharing options...
Montana Posted February 6, 2007 Share Posted February 6, 2007 1. You probably don't have a bulb in that cubby. There isn't one in our '06 but there is one in our '05, so I had the dealer check (thinking it was just burned out) and they said, nope, there isn't one in the '06. Link to comment Share on other sites More sharing options...
rc0032 Posted February 6, 2007 Share Posted February 6, 2007 2. No 3. I do 4. Push the switch the other direction 5. No Ideas Link to comment Share on other sites More sharing options...
rabydanimal Posted February 6, 2007 Share Posted February 6, 2007 3. This will be highly debated. I do my first oil change at 2K. If you live in an average climate and you use synthetic you can get away with 7,500 miles though I do 5,000. You could just go 8,000 and change the filter halfway through . If you're hard on your car and you live in a harsh climate doing it every 3,000 might be a good idea. Generally the 3K 3 month thing is considered an invention of oil companies and those in the car service industry. Link to comment Share on other sites More sharing options...
Alex C Posted February 7, 2007 Author Share Posted February 7, 2007 4: The switch is in the middle, by auto off, I mean the lights stay on even after the 10 minute interval if the door is left open. They do turn off if the doors are closed. Link to comment Share on other sites More sharing options...
