Mines Posted January 31, 2007 Share Posted January 31, 2007 MY carpet hook popped out, how do I put this ish back in?? It just doesn't seem to simply push in Link to comment Share on other sites More sharing options...
axis008 Posted February 1, 2007 Share Posted February 1, 2007 Yes, no, maybe so? http://www.legacygt.com/forums/showthread.php?t=42874&highlight=carpet+hook -ben Link to comment Share on other sites More sharing options...
Mines Posted February 1, 2007 Author Share Posted February 1, 2007 thanks ben, you are my hero When are we gonna go karting again. Call me up if your ever down here. Link to comment Share on other sites More sharing options...
PhiTauFord Posted February 1, 2007 Share Posted February 1, 2007 had mine replaced under warranty when your friendly neighborhood car wash attendant so kindly ripped it out taking my floor mats out one sunny day this past summer. :: remembering fondly :: Link to comment Share on other sites More sharing options...
pillboy Posted February 1, 2007 Share Posted February 1, 2007 Mine came with a metal bracket bolted to the seat rail and a heavy metal snap fastening to hold the floormat to the bracket... it doesn't go anywhere That's why the car is so expensive in Canada. It is still ugly. Link to comment Share on other sites More sharing options...
zmarko Posted February 1, 2007 Share Posted February 1, 2007 That's why the car is so expensive in Canada. Link to comment Share on other sites More sharing options...
pflo Posted February 1, 2007 Share Posted February 1, 2007 Mine came with a metal bracket bolted to the seat rail and a heavy metal snap fastening to hold the floormat to the bracket... it doesn't go anywhere I have the same thing. Unfortunately it doesn't do a thing for the all weather mats. Link to comment Share on other sites More sharing options...
gfxdave99 Posted February 1, 2007 Share Posted February 1, 2007 FYI if you go to the dealer they will replace it for free with a new hook that is actually larger then the one that comes stock. I had mine replaced when i was down in FL in the fall and so far its been fine. The one i had from the factory came out in like 2 months. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
croll326 Posted November 1, 2007 Share Posted November 1, 2007 $5 part and $45 labor at the dealer will fix it. Link to comment Share on other sites More sharing options...
SSN666 Posted November 2, 2007 Share Posted November 2, 2007 Get one of the wall anchors that have the wings that snap out once pushed thru the wall. Drill a hole in the anchor's flat part. Put the screw part of the anchor thru the hole (a washer would be a good idea also). Reattach the 'wings' portion. Slip it thru the carpet (yes there is room below the carpet). Tighten the screw. Anchor never goes anywhere again. Oh, yes. The screw might be so long that it hits bottom and might have to cut it shorter before 'installation'. Check this, but be sure to not cut it so short that you cannot screw the wings back on so that they will still fold ' closed' and allow you to slip thru the carpet hole. Link to comment Share on other sites More sharing options...
biggggant Posted November 4, 2007 Share Posted November 4, 2007 i had my dealer replace mine and they said it was so easy they only charged me for the hook and no labor Link to comment Share on other sites More sharing options...
