NSFW Posted January 31, 2007 Share Posted January 31, 2007 I'm starting to think about a new set of wheels and tires for the non-snow seasons, and have decided that I am most interested in tires that handle well at their limits - how high the limit is, is a secondary consideration. All things being equal, I'd go for summer tires, but I'm not trying to beat anyone on a track... going fast is less interesting to me than just going at the limits, wherever those are, so I figure that it's worth trading off some skidpad Gs if it makes slides more controllable. Any suggestions? Link to comment Share on other sites More sharing options...
Xenonk Posted January 31, 2007 Share Posted January 31, 2007 but more grip = allowable speed, no? I think you are looking for more of smoother transitioning tire.. you maybe looking for something along the lines of a Toyo T1-R or that nature.. the Azenis RT-615s do have some snap-back in them so they might not be a tire for you, you could try a set of Kumho MXs that are also more forgiving than the Azenis.. but I think the Toyo T1-R is what you are looking for. Keefe Link to comment Share on other sites More sharing options...
NSFW Posted January 31, 2007 Author Share Posted January 31, 2007 Sure, but allowable speed is not my main concern, so absolute grip is not my main concern. Perhaps "secondary" was not the best choice of words - I mean distant second. Anyway, "smooth transition" describes what I had in mind. Thanks for the suggestions. Link to comment Share on other sites More sharing options...
robinlsb Posted January 31, 2007 Share Posted January 31, 2007 Sure, but allowable speed is not my main concern, so absolute grip is not my main concern. Perhaps "secondary" was not the best choice of words - I mean distant second. Anyway, "smooth transition" describes what I had in mind. Thanks for the suggestions. Smooth transition from what? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Xenonk Posted January 31, 2007 Share Posted January 31, 2007 smooth transitions, as in the grip level isn't peaky when it comes to the terms of grip.. Race tires like Hoosier have a high grip LIMIT.. but when they fade on you, they REALLY fade on you without much warning. Street tires on the other hand don't have as high as a grip LIMIT, but instead, their grip isn't as peaky.. if they are overdriven, you can tell very easily as they slide in and out of maximum limit of grip gradually. Believe or not, all-season tires are probably a better choice as they are soft enough to fade in and out of dry and wet levels of grip without a lot of drama.. drifting on Potenza RE-92s is really nice to have.. If you want a summer tire, try a set of Falken ST-115s as they are easily controllable with a fair limit of dry grip.. I havent tried other tires that gives that kind of similar grip other than the real CHEAP Kumho 711s that are lower in grip levels and are pretty smooth in transitions from sliding in and out of its grip limit. Keefe Link to comment Share on other sites More sharing options...
PhiTauFord Posted January 31, 2007 Share Posted January 31, 2007 tires are confusing. I've been doing some reading lately. I want a spring summer fall setup and a winter setup. Other than tirerack is there a good resource to get tire information? Link to comment Share on other sites More sharing options...
robinlsb Posted January 31, 2007 Share Posted January 31, 2007 smooth transitions, as in the grip level isn't peaky when it comes to the terms of grip.. Race tires like Hoosier have a high grip LIMIT.. but when they fade on you, they REALLY fade on you without much warning. Street tires on the other hand don't have as high as a grip LIMIT, but instead, their grip isn't as peaky.. if they are overdriven, you can tell very easily as they slide in and out of maximum limit of grip gradually. Believe or not, all-season tires are probably a better choice as they are soft enough to fade in and out of dry and wet levels of grip without a lot of drama.. drifting on Potenza RE-92s is really nice to have.. If you want a summer tire, try a set of Falken ST-115s as they are easily controllable with a fair limit of dry grip.. I havent tried other tires that gives that kind of similar grip other than the real CHEAP Kumho 711s that are lower in grip levels and are pretty smooth in transitions from sliding in and out of its grip limit. I think you missed my point. Did he mean a tire that protests vis noise(screech) or a tire that starts to slide slowly ?A tire that screeches lets you know by the noise, that it it reaching its limit(ala re92). A tire with soft compound simply smokes(ala ds3, GT+4), but the feed back is in the steering. Either way, the time to find out that you have over cooked a corner on a public road, it NOT in the corner!! "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
ogradnis Posted January 31, 2007 Share Posted January 31, 2007 _ Link to comment Share on other sites More sharing options...
NSFW Posted January 31, 2007 Author Share Posted January 31, 2007 I think you missed my point. Did he mean a tire that protests vis noise(screech) or a tire that starts to slide slowly? Screeching is better than nothing, but I'd much prefer a slow slide. Sorry for not being more clear. Link to comment Share on other sites More sharing options...
NSFW Posted January 31, 2007 Author Share Posted January 31, 2007 PhiTauFord & ogradnis, would you guys mind starting threads of your own, to keep this one focused on its topic? Thanks! Link to comment Share on other sites More sharing options...
PhiTauFord Posted January 31, 2007 Share Posted January 31, 2007 sorry. didn't mean to thread-jack ya Link to comment Share on other sites More sharing options...
whitetiger Posted January 31, 2007 Share Posted January 31, 2007 the yokohama advan neova ad07s i had last summer were very good at the transitioning point. on the autox track, my rear was swinging all over the place but i was always able to keep it in line thanks to the tires. They never just broke loose right away, I was always able to bring it back in line. Link to comment Share on other sites More sharing options...
NSFW Posted February 1, 2007 Author Share Posted February 1, 2007 Thanks guys! Link to comment Share on other sites More sharing options...
