Tuned200 Posted January 28, 2007 Share Posted January 28, 2007 Where is the best spot ot route thses thru the firewall? Im trying to install a boost gauge, and the an EGT gauge later. tia. Link to comment Share on other sites More sharing options...
unstablementaly Posted January 28, 2007 Share Posted January 28, 2007 http://legacygt.com/forums/attachment.php?attachmentid=10252&d=1127508842 i ran mine right out the grommet for the hood release. this walk thru link should help you out greatly for running all the hoses. my vBGarage Link to comment Share on other sites More sharing options...
Tuned200 Posted January 28, 2007 Author Share Posted January 28, 2007 http://legacygt.com/forums/attachment.php?attachmentid=10252&d=1127508842 i ran mine right out the grommet for the hood release. this walk thru link should help you out greatly for running all the hoses. thanks man:icon_mrgr Link to comment Share on other sites More sharing options...
unstablementaly Posted January 28, 2007 Share Posted January 28, 2007 no problem, thats what this site is here for! my vBGarage Link to comment Share on other sites More sharing options...
Jim_KT Posted January 28, 2007 Share Posted January 28, 2007 http://legacygt.com/forums/attachment.php?attachmentid=10252&d=1127508842 i ran mine right out the grommet for the hood release. this walk thru link should help you out greatly for running all the hoses. Roger that. I just installed my Omori from J-Spec Tuning this weekend and chose to run the boost/vac line through the same grommet in the link above. My only difference is that I used wire loom from the BPV all the way through the fender and through the grommet hole as a protective shield for the sharper surfaces. The install came out real nice and looks fairly OE under the hood. Link to comment Share on other sites More sharing options...
