WannaScooby Posted January 19, 2007 Share Posted January 19, 2007 I have searched and didn't find my answer or anything on this. I am having issues with my homelink mirror. It took a couple of times for me to be able to set it up where the homelink function and my garage door opener would "talk" to each other and work through the mirror. Well, it only worked for one day and then wouldn't work anymore. I just get a humming noise from the garage door when I try to use the mirror. What is weird is that when homelink stopped opening the garage door and would only hum, all of the remotes for the garage door would only hum when their buttons were pressed. Since then, I haven't been able to get any remote to work even after resetting everything. I now have to open and close my garage door by hand. Has anyone had this happen and if so, how did you fix it? The garage door opener is a Craftsman if that helps and the mirror is OEM. Sorry if this is in the wrong section. Link to comment Share on other sites More sharing options...
ShockerGT Posted January 19, 2007 Share Posted January 19, 2007 Have you checked to see if the actual garage opening unit is not broken? Link to comment Share on other sites More sharing options...
SC GT Posted January 19, 2007 Share Posted January 19, 2007 You posted in the right section. Your problem is odd because all Homelink really does is record the sound/transmission from your garage remote and play it back. It could not re-program your remote nor could it re-program your garage door opener. I'd Google "homelink" and your garage door opener brand and model and see if anyone else has had the same problem. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 Have you checked to see if the actual garage opening unit is not broken? Well...it was humming when I first tried to set everything up and then it started working and then humming again. I guess it could be broken. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 You posted in the right section. Your problem is odd because all Homelink really does is record the sound/transmission from your garage remote and play it back. It could not re-program your remote nor could it re-program your garage door opener. I'd Google "homelink" and your garage door opener brand and model and see if anyone else has had the same problem. I'll give that a shot and see what I find. Thanks guys. Link to comment Share on other sites More sharing options...
ShockerGT Posted January 19, 2007 Share Posted January 19, 2007 Well...it was humming when I first tried to set everything up and then it started working and then humming again. I guess it could be broken. Is it chain driven or screw type opener? Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 Is it chain driven or screw type opener? It's chain driven. The SO doesn't believe it is the garage door opening unit because it only started doing this after I tried to set up the homelink even though I got the homelink to work once and then everything went back to humming. Link to comment Share on other sites More sharing options...
Jon in CT Posted January 19, 2007 Share Posted January 19, 2007 If the unit attached to your garage ceiling is humming, then it's broken. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 Yep, that's what's humming. I can believe that but the SO can't for some reason. Says it just seems too coincidental. I guess I need to go out and get a new one. Argh... Link to comment Share on other sites More sharing options...
bosco Posted January 19, 2007 Share Posted January 19, 2007 ^ +1 all the Homelink does is "tell" the door to open/close. a hum in the opener has nothing to do with the HL. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 I did a few searches on google and I am coming up with either the unit is broken or the unit is stuck. I'm going to see if it is stuck somehow first and then replace it if it is not. Thanks guys. Link to comment Share on other sites More sharing options...
ShockerGT Posted January 19, 2007 Share Posted January 19, 2007 It's chain driven. The SO doesn't believe it is the garage door opening unit because it only started doing this after I tried to set up the homelink even though I got the homelink to work once and then everything went back to humming. It's the gear that moves the chain that's broken, causing your motor work, but not open the door. Had that happen on my old garage door unit. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 It's the gear that moves the chain that's broken, causing your motor work, but not open the door. Had that happen on my old garage door unit. Does the whole unit have to be replaced or just the gear? And did this happen to you when it was cold out? What I kept reading after searching on google is that a lot of people had this hum noise start after it got cold fast. Link to comment Share on other sites More sharing options...
ShockerGT Posted January 19, 2007 Share Posted January 19, 2007 Well, unless you consider 90s cold, then no. It was already dieing as it was 10 years old, so it was replaced with a screw type opener from Genie. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 19, 2007 Author Share Posted January 19, 2007 Oh...no I was meaning 20's. I'm not sure how old this garage door opener is, but the house is an '87. :o Link to comment Share on other sites More sharing options...
bosco Posted January 19, 2007 Share Posted January 19, 2007 Oh...no I was meaning 20's. I'm not sure how old this garage door opener is, but the house is an '87. :o it's more than likely the original opener. why mess around trying to repair a 20yr. old unit just buy a new one the security features on new ones is vastly superior to something from '87 anyway. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
pillboy Posted January 19, 2007 Share Posted January 19, 2007 Does the wall control (which is usually hard wired to the head unit in that vintage of opener) open and close the door? This would verify if the motor works and the problem is in the receiver (it would be odd for all the transmitters to fail at the same time). It is still ugly. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 20, 2007 Author Share Posted January 20, 2007 it's more than likely the original opener. why mess around trying to repair a 20yr. old unit just buy a new one the security features on new ones is vastly superior to something from '87 anyway. bosco We found the date on the unit and it is from 2000. So it's 7 years old. It does have a bunch of security and safety features. Link to comment Share on other sites More sharing options...
WannaScooby Posted January 20, 2007 Author Share Posted January 20, 2007 Does the wall control (which is usually hard wired to the head unit in that vintage of opener) open and close the door? This would verify if the motor works and the problem is in the receiver (it would be odd for all the transmitters to fail at the same time). No...none of them were working. We did fix it. The trolley was stuck on a bolt and coming too far in when it opened the door. We removed the bolt and adjusted it not to come so close to the bolt and fixed it. So...no more broken garage and all the remotes and my homelink is working again. Thanks for the help guys! I really appreciate it. Link to comment Share on other sites More sharing options...
