VanillaEps Posted January 19, 2007 Share Posted January 19, 2007 This picture was taken from the Official Spec B thread. It's a navigation screen shot from a 2007 Spec B. At the top right hand corner is the temperature gauge shown on the map screen of the system. I have not been able to get the temparature gauge to show on my 2006 Spec B. Is it possible to diplay the temperature as well as the clock? If so can someone point me in the right option screen on the 2006 Spec B. Thanks! Link to comment Share on other sites More sharing options...
BDII Posted January 19, 2007 Share Posted January 19, 2007 dont you have a manuel? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
fweasel Posted January 19, 2007 Share Posted January 19, 2007 dont you have a manuel? Manuel? http://www.cocoda.org/Pic-0902/3CRCManuelOrtega.jpg ignore him, he'll go away. Link to comment Share on other sites More sharing options...
edkwon Posted January 19, 2007 Share Posted January 19, 2007 This picture was taken from the Official Spec B thread. It's a navigation screen shot from a 2007 Spec B. At the top right hand corner is the temperature gauge shown on the map screen of the system. I have not been able to get the temparature gauge to show on my 2006 Spec B. Is it possible to diplay the temperature as well as the clock? If so can someone point me in the right option screen on the 2006 Spec B. Thanks! It's in the options, trust me, same menu settings that allow you to change units from mph to kph and turn off the beep when you touch the screen, look around, you'll find it. If you dont believe me, i got it to work on my car, and dont say its because i have an 07. its the same damn nav unit http://img277.imageshack.us/img277/5784/navihackys4.jpg Ed Link to comment Share on other sites More sharing options...
alphabit Posted January 19, 2007 Share Posted January 19, 2007 I will check my car on my way to work, see if its the same for the 06, and I will post how I did it, and see if you can duplicate it. and then post my finding, however if someone bets me to this, I will not post anything. Link to comment Share on other sites More sharing options...
alphabit Posted January 19, 2007 Share Posted January 19, 2007 OK, hit the INFO button on the top there is a menu to select from pick SET now you will see a menu at the top where you can set various settings the very first menu you can select should have: BEEP - ON/OFF - this is for the beep when you hit the screen( annoying) TEMP - OFF/MAP - this displays the outside temp on the map or not TIME - 10/20/30 - displays the TIME on the map for number of selected settings I hope this helps :O Link to comment Share on other sites More sharing options...
VanillaEps Posted January 19, 2007 Author Share Posted January 19, 2007 I just checked. Followed the direction and menus posted. I don't have the option to display the temperature on the map. When in the Set menu, I have the option to display the temperature ON or OFF; not MAP. The ON option allows the temperature to be displayed anytime, but the map. The OFF option does not display the temperature at anytime. Interesting. I also checked the Menu that Edkwon described and there's nothing there either. Thanks though. Link to comment Share on other sites More sharing options...
alphabit Posted January 19, 2007 Share Posted January 19, 2007 Ah, that sucks. Link to comment Share on other sites More sharing options...
BDII Posted January 19, 2007 Share Posted January 19, 2007 Manuel? I was hoping someone would get that Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
VanillaEps Posted January 19, 2007 Author Share Posted January 19, 2007 I'll check my manuel when I get home. If I get it to work, I'll post a reply. Anyone with an 06 that has gotten this to work, please reply... Link to comment Share on other sites More sharing options...
hybridandy Posted January 19, 2007 Share Posted January 19, 2007 I'll have to check when I leave work but we may not have that Map option but I'll have to check for sure. I just usually hit the far right button and it will display the time, date and temperature. Link to comment Share on other sites More sharing options...
DukeTrout Posted January 19, 2007 Share Posted January 19, 2007 Could you update your software with the 2007 disks to get the same options? I thought they were the same physical Kenwood unit? Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
VanillaEps Posted January 19, 2007 Author Share Posted January 19, 2007 I'll have to check when I leave work but we may not have that Map option but I'll have to check for sure. I just usually hit the far right button and it will display the time, date and temperature. That's what I've been doing as well. But, when I saw the picture, I figured I'd ask the question. I just took the Navigation tutorial found on the DVD, but no mention of the clock or temperature options... Link to comment Share on other sites More sharing options...
Jon in CT Posted January 19, 2007 Share Posted January 19, 2007 You'll need to look in the owner's manual supplement for the display screen. My screen overlays time on the map, but not temperature. To view temperature I have to hit the INFO button. Link to comment Share on other sites More sharing options...
