legacyboy8929 Posted January 17, 2007 Share Posted January 17, 2007 i have a automatic 07 legacy limited, and i wasnt sure if a aftermarket turbo or other parts, would work on it even though its made for a legacy gt? Link to comment Share on other sites More sharing options...
MarcusDubya77 Posted January 18, 2007 Share Posted January 18, 2007 Turbo charging an N/A is a bit harder than that..The compresion ratios are different than the Turbo, but don't let that deter you..If you have a dream, then follow it!!! Welcome to the boards. :woowoo:check out the Diamond Gray Metallic Monster!!! Link to comment Share on other sites More sharing options...
Guest subiecity Posted January 18, 2007 Share Posted January 18, 2007 it would work but the NA cars have a higher compression ration and we would probably screw up the engine majorly if we had 18 psi with 10.1 compression ration or watever we have, probably safely id say 4-8 psi would be plenty boost for our NA cars, 6 psi on a NA car would feel like 20 psi in the LGT, its not worth it tho if u are tryin to turbo charge a NA legacy theres a lotta work involved besides parts u need a good tune and really take care of your ecu ur better off with an LGT save time and money Link to comment Share on other sites More sharing options...
