J.R. Posted January 13, 2007 Share Posted January 13, 2007 I'm trying to hook up some gauges, and was going to use the radio for power, ground, etc. Does anyone have the pin out for the radio, or know which wire is what? I need a ground, constant 12v, and switch 12v. Thanks Jim Link to comment Share on other sites More sharing options...
Jon in CT Posted January 14, 2007 Share Posted January 14, 2007 Can you can post a legible picture of the label on the bottom of the chassis? It should look like this: http://i4.ebayimg.com/05/i/000/81/12/a572_1.JPG Even if you can't, simply reporting the Model No. and Ref.No. would be OK and would prompt me to dig up the info you're after. Link to comment Share on other sites More sharing options...
J.R. Posted January 14, 2007 Author Share Posted January 14, 2007 I was trying to take apart the dash a little as possible . I'll try to get you a picture at some point. Don't have a lot of free time for the next week or so though. It should be the same as an 05-06, since the 07 radio is plug and play with those years. Link to comment Share on other sites More sharing options...
Jon in CT Posted January 14, 2007 Share Posted January 14, 2007 It should be the same as an 05-06, since the 07 radio is plug and play with those years.It's not the same. Link to comment Share on other sites More sharing options...
Deer Killer Posted January 15, 2007 Share Posted January 15, 2007 This is what you are looking for, no? http://www.geocities.com/svxdc/WRX-pinout.htm Link to comment Share on other sites More sharing options...
J.R. Posted January 15, 2007 Author Share Posted January 15, 2007 I'll look and see if that'll work. Thanks If not, I'll still post the picture of the part numbers Link to comment Share on other sites More sharing options...
J.R. Posted January 18, 2007 Author Share Posted January 18, 2007 Deer Killer - I believe that diagram will work for me, thanks Jon- The part numbers on the label are : MODEL NO: 86201AG67A REF NO: CQ-EF1661X Link to comment Share on other sites More sharing options...
