drcaveman Posted January 9, 2007 Share Posted January 9, 2007 I have the Service manual section for the power windows see attached JPGs. How can I use these to make the driver door panel make the windows go auto up and down or at the very least go auto down. I would love to know if its possible. Link to comment Share on other sites More sharing options...
loak Posted January 9, 2007 Share Posted January 9, 2007 i think there's a summary of what parts are needed on one of the last pages. http://www.legacygt.com/forums/showthread.php?t=17070 edit: actually, this might be a decent summary of the thread I think the cost is containable (DEI530T module $53.07, and a 5 pole relay, with leads, for $15 and finally an in-line fuse for $5). This is for just the front windows. Tack on another $53.07 for the back windows if you so desire... No changes in the switches required. After the install, they work as if by magic: Press and hold down for a second and the windows automatically go down. If you press or lift while the windows are traveling, they will stop. Lift and hold up for second and they will go automatically up. If you press or lift while the windows are traveling, they will stop. No extra pressure or extra clicks... Link to comment Share on other sites More sharing options...
