buzzing/vibration sound
ejb3232
I just noticed my legacy being louder than normal lately. It makes a buzzing sound coming from the front when I get over 45 mph. I can even feel a slight vibration in the gas pedal. It still makes the noise when I take my foot off the pedal as long as Im over 45 mph. I also have issues with a scraping sound every once in a while from the driver side wheel in case that would have anything to do with the sound. Any ideas? Ill probably get it checked this week but wanted to see if anyone had a similiar problem.
Things that do what you are talking about:
Wheel Bearings
Pinion Gear Bearing
Center Diff
Rear Diff
Front Diff
My advice after two months of trying to track down a similar problem. Take it in to a shop. Describing sounds; humming, vibration, etc., is very subjective and most of the problems cannot be tested for without dis-assembly or an experienced tech.
