rporter Posted October 14, 2004 Share Posted October 14, 2004 When I was looking at the car when I ordered a few months ago, I swore that it had a power outlet in the LR corner. I must have looked at an Outback (which has it), and the Legacy has a blank cover plug there. Anyone know if the wiring back there already has a connector that would just require plugging in and drilling the hole to add the outlet? I would like it, but don't want it bad enough to be splicing up wires back there to get it. Ron Link to comment Share on other sites More sharing options...
Red98GT Posted October 15, 2004 Share Posted October 15, 2004 I got bored one day and pulled of of the plugs out of mine.. I was not able to see any wiring in there, however never pulled the entire panel off. Hopefully there is something back there.. I think an extra outlet is not a bad idea at all.. Link to comment Share on other sites More sharing options...
Fraberg Posted October 15, 2004 Share Posted October 15, 2004 I have a Norwegian spec. 2005 Outback and this does not have a rear power outlet. However, as you said, there is a place for it LR side in the trunk. I spoke to the mechanics at my local Subaru dealer, and he said that it was no wiring ready for a 'quick install'. He said that it was quite easy to find power back there but one should be a bit careful since the car has a modern LAN (local are network). I recommend that you ask Your dealer about which wires to use. Link to comment Share on other sites More sharing options...
