C_randyjones Posted January 2, 2007 Share Posted January 2, 2007 I have been searching around the web with no results. Link to comment Share on other sites More sharing options...
SC GT Posted January 2, 2007 Share Posted January 2, 2007 http://legacygt.com/forums/showthread.php?t=51189 Edit: Sorry, I think these are JDM GT springs, not JDM Spec B springs. Link to comment Share on other sites More sharing options...
jim1969 Posted January 2, 2007 Share Posted January 2, 2007 what are you planning on mating them to? Link to comment Share on other sites More sharing options...
C_randyjones Posted January 2, 2007 Author Share Posted January 2, 2007 I intend to install them on factory struts of my legacy GT. Link to comment Share on other sites More sharing options...
jim1969 Posted January 2, 2007 Share Posted January 2, 2007 talk to unclemat. I have JDM spec B, Rev C springs. I'm not sure if there's a difference in the springs with the different revisions or just the dampeners. Link to comment Share on other sites More sharing options...
HansGT Posted February 2, 2007 Share Posted February 2, 2007 I intend to install them on factory struts of my legacy GT. they are designed for JDM top hats. You'll need some USDM spec b tophats or JDM tophats. Link to comment Share on other sites More sharing options...
rexster Posted February 3, 2007 Share Posted February 3, 2007 they are designed for JDM top hats. You'll need some USDM spec b tophats or JDM tophats. they'll work with USDM GT tophats, but the front will be lowered by about 1/2 inch from stock height and back will be about the same as stock. the bilstein specific (JDM) mounts won't work with the stock USDM GT struts, so you'll need new struts if you use them. why do you want rev A spec b springs? you can get USDM spec B springs easily from any US dealer for much less, and I doubt there's much difference. or you can find someone with a US spec B who just installed pinks and buy them used. if you really need that revision new I would call gruppe-s. they regularly import from japan. they will have to make some calls to get the part numbers, it will take 6-8 weeks and will cost around $369, the same as pinks. Link to comment Share on other sites More sharing options...
darb1 Posted February 27, 2007 Share Posted February 27, 2007 I have a set of JDM spec B rev. A bilstiens on the way and don't need the springs though they are for a Wagon. Link to comment Share on other sites More sharing options...
