B4-3.0RspecB Posted December 30, 2006 Share Posted December 30, 2006 Does anyone know if the Bilstein struts are adjustable? My '05 JDM B4 3.0R Spec B is a great handling car but seems to have the fast bump dialed out. During hard cornering with the front outside wheel loaded the car will bottom out on the front suspension stops when there is a sharp (but not big) bump mid corner. It feels like there is no dampening at all. This could be a fault with my car or it could be the factory setup has not allowed for the rough roads here in New Zealand. Has anyone else experienced this problem? Is there a fast bump adjustment on this suspension? Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2006 Share Posted December 31, 2006 Stock Bilsteins are not adjustable. If you want more complaint suspension you can go for JDM GT. Spec B Bilsteins are kinda rough. Mine when I hit a sharp bump transfer the hit to the chassis real hard. Link to comment Share on other sites More sharing options...
