toshiba2.5 Posted December 25, 2006 Share Posted December 25, 2006 ok will buffing the car get rid of some scratchs from rocks and such, what is a best way of getting rid of a lil annoying kinda looks deep scrath haha thanks Link to comment Share on other sites More sharing options...
G.T.Subie Posted December 25, 2006 Share Posted December 25, 2006 Can't fix a scratch without touching it up or repainting. Buffing may dull it or you can use a swirl remover with fillers to help hide the scratch depending on how big it is. Check http://paintscratch.com/ Denial is your best friend Link to comment Share on other sites More sharing options...
toshiba2.5 Posted December 25, 2006 Author Share Posted December 25, 2006 ok i just went to look at the scratch i want gone. it doesnt look like it went into the paint i think it just the clearcoat but its still kinda deep. its a very small scratch... so you think just tryin to wax it or buff it will make it not as noticeable Link to comment Share on other sites More sharing options...
G.T.Subie Posted December 25, 2006 Share Posted December 25, 2006 If you rub your finger nail over it and can feel it, it is through the clear. Denial is your best friend Link to comment Share on other sites More sharing options...
kenchan Posted December 25, 2006 Share Posted December 25, 2006 try some ScratchX and apply by hand. if you give it some elbow grease and the scratch doesn't come off or improve by the 4th app, it's most-likely through the clear. Link to comment Share on other sites More sharing options...
OCDetails Posted December 28, 2006 Share Posted December 28, 2006 ^^ Yeah, that. Try removing it with ScratchX. If it doesn't come out that way then it is probably deeper than what can be removed by hand. Wax won't do diddly to remove it because wax isn't abrasive. Using wax to remove scratches is like trying to sand a table with Pledge. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
LIZARD Posted December 28, 2006 Share Posted December 28, 2006 ^^ Yeah, that. Try removing it with ScratchX. If it doesn't come out that way then it is probably deeper than what can be removed by hand. Wax won't do diddly to remove it because wax isn't abrasive. Using wax to remove scratches is like trying to sand a table with Pledge. WHAAATTTT??!!! You mean you can't sand with pledge?????!! Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
