deeslk Posted December 16, 2006 Share Posted December 16, 2006 Does anyone know if there is a difference in the suspension in a regular 07 Legacy 2.5i and a Legacy 2.5GT. Thanks Link to comment Share on other sites More sharing options...
ebpda9 Posted December 17, 2006 Share Posted December 17, 2006 i know the 05-06 2.5i's had a softer suspension, so i would imagine that the same holds true for the 07's. there is no physical difference in the parts. Link to comment Share on other sites More sharing options...
ShockerGT Posted December 18, 2006 Share Posted December 18, 2006 2.5i has different struts than the GT. Springs may be different too. GT has slightly stiffer swaybars front and rear too. Link to comment Share on other sites More sharing options...
Guest subiecity Posted December 19, 2006 Share Posted December 19, 2006 struts were different? the ones i bought mounted just fine for the front and rear, i have a 2.5i and these were off a gt Link to comment Share on other sites More sharing options...
ShockerGT Posted December 19, 2006 Share Posted December 19, 2006 They are different in terms of dampening and rebound. The GT struts are better suited for handling on lowering springs. Trust me, I did the test on my old 2.5i with pinks on stock struts and same springs on GT struts. Plus, part numbers are different. Link to comment Share on other sites More sharing options...
rzar Posted January 11, 2007 Share Posted January 11, 2007 So would aftermarket lowering springs for the GT work on the 2.5i? Link to comment Share on other sites More sharing options...
SeattleLegacy Posted January 11, 2007 Share Posted January 11, 2007 ^^^sure, but you're better off getting the GT dampners and putting the springs on those. the 2.5i ones are pretty floaty (due to less dampening) and with the higher rate of lowering springs, you'll get a lot of bounce. Link to comment Share on other sites More sharing options...
