SSN666 Posted December 12, 2006 Share Posted December 12, 2006 I can't find the answers in a simple search or in the manuals and I don't want to take parts off just to find these answers. 1) On a 2005 LGT wagon the trans cooler lines go to the radiator (well known I'm sure) but at the spot just ahead of the battery one is routed to under the battery and then comes back out. I don't want to remove the battery just for curiosity, so why is this so? Thermal expansion seems unlikely. Whats under there? 2) I saw a comment somewhere that there is an external filter on the 5AT sport transmisison? Is that true? I have been thinking of adding an external trans filter but there is not a lot of room in the engine compartment. Link to comment Share on other sites More sharing options...
automaticsti Posted December 20, 2006 Share Posted December 20, 2006 yeah, i beleive its under the battery, its not that bad to remove, you will have to if you ever want to change the blinker on that side. Link to comment Share on other sites More sharing options...
jerseyglock Posted December 20, 2006 Share Posted December 20, 2006 Yes, there is a tranny filter. Its right above the windshield washer tank. Remove front bumper when change filter, less mess. Link to comment Share on other sites More sharing options...
SSN666 Posted December 21, 2006 Author Share Posted December 21, 2006 Thanks, I found it. Once I knew the area, I looked thru a small space between the battery and fender and there it was. You two answered both questions. The 'mystery' lines are the supply and return for the filter. Link to comment Share on other sites More sharing options...
