BIU Posted December 12, 2006 Share Posted December 12, 2006 I've done some searching but havent found any detailed info on this.. but does anyone know if theres a certain size for the LED bulbs in the side mirrors and any info on how to go about taking them out and replacing them? Thanks Link to comment Share on other sites More sharing options...
Drewski Posted December 13, 2006 Share Posted December 13, 2006 I've done some searching but havent found any detailed info on this.. but does anyone know if theres a certain size for the LED bulbs in the side mirrors and any info on how to go about taking them out and replacing them? Thanks they are not [easilly] replacible. You would need to crack them open and UNSOLDER the ones inside, find the resistors and check what values they are, solder in the new LEDs and solder in the appropriate resistors (different colors and brands use different power and thus need different resistors) to keep them safe. unless you are adept to soldering and have at least rudimentry electronics skills, I would steer clear or find someone who can do it for you... or if it is to replace exactly what is already in there b/c it is not working - just take that to the dealer.... save yourself the greif. If you DO decide to "go for it", post pics. What color were you thinking of moving to? Link to comment Share on other sites More sharing options...
Fri501pm25 Posted October 3, 2007 Share Posted October 3, 2007 japanparts.com has replacement lens for the side mirrors part number 107-021-003 and they have mulitcolors....they are called grandpas eye kit....... Link to comment Share on other sites More sharing options...
