tarmacstage Posted December 7, 2006 Share Posted December 7, 2006 Hello All, I recently purchased an '03 Legacy Outback Limited. How hard do you need to push down on the tilt adjust lever to unlock the steering wheel? I want to adjust the steering wheel upwards (feels like it's at its lowest position). When I went to push the adjust lever down, it won't budge. Am I doing something wrong? I can't get the colum to unlock so I can move it. Thanks, -CJ Link to comment Share on other sites More sharing options...
Bez Posted December 7, 2006 Share Posted December 7, 2006 Pull the lever towards you, move the wheel up to where you want it and then push the lever away from you to lock it. Link to comment Share on other sites More sharing options...
tarmacstage Posted December 7, 2006 Author Share Posted December 7, 2006 Pull the lever towards you, move the wheel up to where you want it and then push the lever away from you to lock it. Thank you! Sure enough, I was able to glance down in the bright light of the morning and see the lever is of robust construction, and just needed a little more pressure than the same adjustment on a Subaru GL I owned years ago. Link to comment Share on other sites More sharing options...
