eavr4 Posted October 9, 2004 Share Posted October 9, 2004 Am currently trying out the above....any suggestions? EA Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 9, 2004 Share Posted October 9, 2004 [url]www.dictionary.com[/url] Link to comment Share on other sites More sharing options...
Xenonk Posted October 10, 2004 Share Posted October 10, 2004 Try Prova Hood Struts... Keefe Keefe Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 10, 2004 Share Posted October 10, 2004 NOT for 349! I'd rather expirement with different hood struts from Pepboys. Link to comment Share on other sites More sharing options...
red beast Posted October 11, 2004 Share Posted October 11, 2004 don't do it! people with wrx's had the same idea, unfortunately you can bend your hood. Link to comment Share on other sites More sharing options...
eavr4 Posted October 11, 2004 Author Share Posted October 11, 2004 [quote name='red beast']don't do it! people with wrx's had the same idea, unfortunately you can bend your hood.[/QUOTE] Bend the hood??? Sorry dun understand?? Cos' I did it for my Galant previously as well as my Odyssey...no issues... Why Legacy will bend hood? EA Link to comment Share on other sites More sharing options...
mccorry Posted October 11, 2004 Share Posted October 11, 2004 It is aluminum..... Link to comment Share on other sites More sharing options...
ssaldana Posted October 11, 2004 Share Posted October 11, 2004 taggin along on this thread as well Link to comment Share on other sites More sharing options...
red beast Posted October 11, 2004 Share Posted October 11, 2004 guess you gotta ask "why didn't subaru do it?". go to nasioc.com and do a search. very few have done it. it does work but you must close it slowly at first or it will bend. Link to comment Share on other sites More sharing options...
Xenonk Posted October 12, 2004 Share Posted October 12, 2004 There's also not much of a hood-to-fender clearance for a hood strut to fit into that seam.. Keefe Keefe Link to comment Share on other sites More sharing options...
eavr4 Posted October 12, 2004 Author Share Posted October 12, 2004 [quote name='Xenonk']There's also not much of a hood-to-fender clearance for a hood strut to fit into that seam.. Keefe[/QUOTE] Errmm...it will not be fitted at the trim...as our bonnet screw is more inward...meaning its gonna be along the trim EA Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 12, 2004 Share Posted October 12, 2004 I could see it bending the aluminum hood. I wonder if it could be mounted toward the front, instead of near the rear or middle- that way it might be a bit stronger. Link to comment Share on other sites More sharing options...
eavr4 Posted October 13, 2004 Author Share Posted October 13, 2004 [quote name='jedimaster']I could see it bending the aluminum hood. I wonder if it could be mounted toward the front, instead of near the rear or middle- that way it might be a bit stronger.[/QUOTE] Thx for the tip...will take note when I do the little project. EA Link to comment Share on other sites More sharing options...
