cwmiller Posted November 23, 2006 Share Posted November 23, 2006 06 OBxt fog light bulbs are a 9006 55w. Can I jump to an 80watt with out melting anything, or any other sort of damage. Link to comment Share on other sites More sharing options...
Xenonk Posted November 23, 2006 Share Posted November 23, 2006 most likely you will since the amp draw is high and the wires are lame and can't handle the current. What you could do is get an HID kit Keefe Link to comment Share on other sites More sharing options...
mccorry Posted November 23, 2006 Share Posted November 23, 2006 +1.... I wouldn't jump up in wattage that much. The fixture, relays, and wiring probably won't handle it very well. Link to comment Share on other sites More sharing options...
John M Posted November 23, 2006 Share Posted November 23, 2006 I don't see why it would be all that much -- you're talking 2.5 more amps per bulb. Going from 4.5 amps to 7 amps per bulb shouldn't make it go up in flames. Increased heat can shorten bulb life but that's probably the only drawback. At least the OB has some real lights -- nice big reflectors and almost twice the wattage of the LGT's lights. Link to comment Share on other sites More sharing options...
