blklgt05 Posted November 17, 2006 Share Posted November 17, 2006 im planning on getting the Cusco rear swaybar + Cusco rear endlinks. Anyone has sways from cusco? any problem with the oem brackets? do their endlink clunk during turns? mod journal Link to comment Share on other sites More sharing options...
forestir Posted November 17, 2006 Share Posted November 17, 2006 I have the non-adjustable 21mm rear bar, stock endlinks, on OB-XT. OEM brackets work fine, no clunks or squeaks. Mine came with rubber bushings, some might come with polyurethane, so YMMV. Link to comment Share on other sites More sharing options...
bosco Posted November 18, 2006 Share Posted November 18, 2006 cusco f/r sways tein h-tech springs stock end links no noise no problem corners flatter ride not affected. http://www.rallitek.com.bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Xenonk Posted November 18, 2006 Share Posted November 18, 2006 not a problem even with stock endlinks, and I race my car and put it through some abuse suspension wise... it's fine. Keefe Link to comment Share on other sites More sharing options...
blklgt05 Posted November 18, 2006 Author Share Posted November 18, 2006 does Cusco RSB comes with urethane bushings? is there problem with the mounting bracket? if not Cusco endlink, can you suggest one that is less likely to cause that 'clunk' noise ive been hearing about? thx mod journal Link to comment Share on other sites More sharing options...
SnoDork Posted November 18, 2006 Share Posted November 18, 2006 Cusco RSB's come with new hard rubber bushings. No need for aftermarket endlinks (like Xenonk/keefe mentioned) I ran my first track event with my car with Cusco RSB and OEM endlinks, and the car handled great... I've got no clunks or noises... hope that helps! ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
blklgt05 Posted November 18, 2006 Author Share Posted November 18, 2006 thx.. i guess i can always get the endlinks later on. mod journal Link to comment Share on other sites More sharing options...
robsontuning Posted November 19, 2006 Share Posted November 19, 2006 I run the Cusco from and rear swaybars on s-tech springs, with AVO endlinks. Link to comment Share on other sites More sharing options...
bosco Posted November 19, 2006 Share Posted November 19, 2006 I run the Cusco from and rear swaybars on s-tech springs, with AVO endlinks. ^ and? bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
blklgt05 Posted November 19, 2006 Author Share Posted November 19, 2006 ^ and? bosco +1 I'm probably just gonna get the Cusco RSB for now, see how it goes on the 'touge' If i do get spherical endlinks later on, which one should i get? Cusco, Whiteline, Agency, Perrin, Cobb??? mod journal Link to comment Share on other sites More sharing options...
robsontuning Posted November 19, 2006 Share Posted November 19, 2006 ^ and? bosco And no problems. I run with the factory endlinks for about a month and completed in 1 autocross with the factory endlinks with no problems. Link to comment Share on other sites More sharing options...
Xenonk Posted November 19, 2006 Share Posted November 19, 2006 heh, I ran with stock endlinks with all my other upgraded suspension for 2 years now (55,000+ miles) and some of that driving includes 200 miles worth of autocrosses and about 3000+ miles on the track and of course, another 100 miles on the http://www.tailofthedragon.com Unless your "touge" looks like the Dragon, the rest [iMHO] is just a straight road Here's a map of the Dragon: http://www.tailofthedragon.com/maps/poster2005.jpg http://www.tailofthedragon.com/maps/elevation.gif What you will get eventually is that your rubber Lower Control Arm bushings will wear out and start ripping apart, but it will still be intact. That's where you can get a probable clunk. Eventually, I will end up buying a set of Spec B aluminum control arms and upgrade those with SuperPro/Whiteline LCA offset-bushings which will give me a little bit more caster (at least that's what I remember them as being offseted). Keefe Link to comment Share on other sites More sharing options...
Joon525 Posted November 19, 2006 Share Posted November 19, 2006 I have the non-adjustable 22mm rear bar, stock endlinks, on OB-XT. OEM brackets work fine, no clunks or squeaks. Mine came with rubber bushings, some might come with polyurethane, so YMMV. I thought the Cusco rear bar was 21mm? Link to comment Share on other sites More sharing options...
forestir Posted November 19, 2006 Share Posted November 19, 2006 I thought the Cusco rear bar was 21mm? Yeah, you're probably right. I don't remember exactly... it's this one: http://www.rallitek.com/cu21reswbar.html. Link to comment Share on other sites More sharing options...
Xenonk Posted November 19, 2006 Share Posted November 19, 2006 it's a native 21mm, but the Cusco version I have (Vacanza, that is now discontinued to be sold in the USA) is an adjustable rear to make act like a 23mm bar. I have my rear bar set to the stiffer setting and it's been fine all these miles. Keefe Link to comment Share on other sites More sharing options...
HansGT Posted November 20, 2006 Share Posted November 20, 2006 Cusco Front (23mm) and Rear (21mm) w/ rubber bushings. iON springs stock endlinks stock wheels/tires no issues Link to comment Share on other sites More sharing options...
blklgt05 Posted November 21, 2006 Author Share Posted November 21, 2006 What you will get eventually is that your rubber Lower Control Arm bushings will wear out and start ripping apart, but it will still be intact. That's where you can get a probable clunk. Eventually, I will end up buying a set of Spec B aluminum control arms and upgrade those with SuperPro/Whiteline LCA offset-bushings which will give me a little bit more caster (at least that's what I remember them as being offseted). Glendora mountain road (GMR). theres like, 1 or 2 short straight. the rest is turn after turn. Im planning on getting the superpro offset bushings too. i wanna see which makes what kind of difference. So my plan for suspension is swaybar, whiteline steering bushing + Superpro offset bushing, then start with power upgrades. Im currently running on BFG gforce sport and MR coilovers. ...yeah.. i also need some skill upgrade. seat time..need to have more seat time mod journal Link to comment Share on other sites More sharing options...
Xenonk Posted November 21, 2006 Share Posted November 21, 2006 I noticed that all seaon tires hate having too much camber.. caster adds dynamic camber (meaning when you turn the wheel more, you gain more camber). any tire that has soft sidewalls won't like having too much camber, so keep the camber to around -1.5 degrees or so.. if you end up getting more than +7 caster, make sure you are around the -1.5 degree for camber for street driving.. you might want to re-dial in your coilovers and tire pressures to make use of the new parts. Keefe Link to comment Share on other sites More sharing options...
blklgt05 Posted November 21, 2006 Author Share Posted November 21, 2006 I noticed that all seaon tires hate having too much camber.. caster adds dynamic camber (meaning when you turn the wheel more, you gain more camber). any tire that has soft sidewalls won't like having too much camber, so keep the camber to around -1.5 degrees or so.. if you end up getting more than +7 caster, make sure you are around the -1.5 degree for camber for street driving.. you might want to re-dial in your coilovers and tire pressures to make use of the new parts. i got rid of my all season long time ago. and im already at -1.5. gives me better entry on turns. my tire pressure is at stock 35/33 since im running stock tire size. and i think my front is a little bit lower than the rear. any suggestions? mod journal Link to comment Share on other sites More sharing options...
