kscottw Posted November 15, 2006 Share Posted November 15, 2006 I bought a B4 badge from Renick motorsports and after receiving it i noticed that it looks as if it is supposed to be placed in a spot that has two little holes. Is this suppose to replace the Subaru Stars emblem or where is it suppose to go? Link to comment Share on other sites More sharing options...
cbroo Posted November 15, 2006 Share Posted November 15, 2006 sounds like you got the emblem for the 00'-04' models we have two small holes on the left rear end of the trunk, you'll probably haft to mess with the emblem to get it to work on your ride. you puttin it on your grill or rear of the car? Link to comment Share on other sites More sharing options...
kscottw Posted November 15, 2006 Author Share Posted November 15, 2006 i want to put it on the rear. I was wondering if i could just cut off those two little pieces because it still has an adhesive back. Also, i want to place it on the right side but am not sure where in relation to the trunk where it should go or where it would look best? Link to comment Share on other sites More sharing options...
cbroo Posted November 15, 2006 Share Posted November 15, 2006 yea I was about to say cut off the little tabs and where to put it is up to you, hard to say where to put an emblem thats not going on my car, but put it on the right side of the trunk where the 2.5GT emblem is. Link to comment Share on other sites More sharing options...
kscottw Posted November 15, 2006 Author Share Posted November 15, 2006 Cool, thanks for the help man. Link to comment Share on other sites More sharing options...
Hanger Posted November 15, 2006 Share Posted November 15, 2006 i cut the two prungs off http://i33.photobucket.com/albums/d70/Hangerr/000_0173.jpg ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
kscottw Posted November 16, 2006 Author Share Posted November 16, 2006 How did you make sure it was straight? Did you just eye it or use a straight edge of some kind? Link to comment Share on other sites More sharing options...
Hanger Posted November 16, 2006 Share Posted November 16, 2006 mine is a bit off... i place the badge on a piece of paper and cut a hole, just match the bottom line of the reverse light, and match the paper to any horizontal line... ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
automaticsti Posted November 17, 2006 Share Posted November 17, 2006 nice Link to comment Share on other sites More sharing options...
Scubbie B4 Posted May 15, 2008 Share Posted May 15, 2008 Nice look, you know need to get the Subaru Aluminium Carbon Fibre Badge Link to comment Share on other sites More sharing options...
hutru01 Posted May 15, 2008 Share Posted May 15, 2008 mine is a bit off... i place the badge on a piece of paper and cut a hole, just match the bottom line of the reverse light, and match the paper to any horizontal line... I have this same badge, although it used to be on a grill and was epoxied to the previous grill. I just cut the badge out of the grill mesh and saved the badge. I am wondering if a dremel will do the trick in order for me to be able to get it flat. What did you use to put it on? 3M? Link to comment Share on other sites More sharing options...
