boora Posted November 12, 2006 Share Posted November 12, 2006 I have seen some wear about the outside edge of my driver back tire. The car seems to sit well, but the wear is definetly different than in the other tires. I have only had to rotate the tires once but this particular tire is almost threadless on the outside 1 inch. Any thoughts on what could be wrong and the fix? Thanks! Link to comment Share on other sites More sharing options...
Dazma Posted November 12, 2006 Share Posted November 12, 2006 Either tire pressure or a suspension problem. No matter how you drive you should always see the most wear on the front tires of an all wheel drive vehicle. Link to comment Share on other sites More sharing options...
forestir Posted November 12, 2006 Share Posted November 12, 2006 Take it in to be inspected. Not normal. Could be bad alignment problem. Link to comment Share on other sites More sharing options...
ih8vtec13 Posted November 12, 2006 Share Posted November 12, 2006 have you been drifting? If you havent then get it looked at, suspension or alignment issue. Link to comment Share on other sites More sharing options...
boora Posted November 12, 2006 Author Share Posted November 12, 2006 I went by the dealer for an alignment, but they could not get me in. I hate having to make appointments. Apparently alignment is covered under warranty as long as < 12K miles? Link to comment Share on other sites More sharing options...
Dazma Posted November 12, 2006 Share Posted November 12, 2006 better take mine in then Link to comment Share on other sites More sharing options...
