Saul_Good Posted November 9, 2006 Share Posted November 9, 2006 I was surfing around and found this. Thoughts? http://shop.quicktimeperformance.com/cart.php?m=product_detail&p=8 Link to comment Share on other sites More sharing options...
lucas569 Posted November 9, 2006 Share Posted November 9, 2006 looks cheaply made, and i cant even imagine how loud that would be. i can only see something like this for the track but in that case i would just unbolt the from the cat back. Link to comment Share on other sites More sharing options...
TSiWRX Posted November 9, 2006 Share Posted November 9, 2006 Depends on your current power level - as well as what's "after" the cut-out. Case-in-point would be brother team23jordan. His post cut-out setup is a totally catless system using 3" piping, mated to very free-flowing exhaust canisters. Last I can remember, he cited that his neighbors had complained as to his exhaust volume. With his setup, a cut-out, even professionally tuned-for, gained him barely any additional power at all. I think that the total gain with cut-out open was less than 2 wHP and a similar small increase in torque. However, if you're pushing significantly more power (he was typical "Stage II+" at the time, I believe), or if you have significant downstream restrictions past the cut-out, you should be able to see much more of an increase. It all depends on the setup. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
