fatbastard Posted November 7, 2006 Share Posted November 7, 2006 Not really sure what is happening here. I have had the Jazzy board for a while and never had a problem but recently started to notice that the silent cd would jump around. I have always had the cd in slot 1 and like I mentioned on occasion it will just jump around, I wasn't sure what was causing this so I checked the CD is seems clean and I didn't see any scrathces. Last time it happened I tried muting the XM radio to see if it was something odd with teh output but no change. Next I played disc 2 and there were no skips at all, then played the XM over disc 2 and again no problem. So it apperas to be an issue with disc 1 or the silent cd. Next time I go out I'll switch the silent cd to disc 2 to see if the problem follows. If not how do I make a silent CD? Anyt other ideas on things to try? Has anyone else seen this? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted November 7, 2006 Share Posted November 7, 2006 CD-Rs and DVD-Rs don't last forever. CD-ROMs are actually mechanically printed so they don't grade. CD-Rs degrade. It sound like you need a new blank CD. The instructions are on jazzy's website and thread. I've had this happen to some CD-Rs. Link to comment Share on other sites More sharing options...
jazzymt Posted November 7, 2006 Share Posted November 7, 2006 Yea - it must either be degrading, or some other defect in the disc is finally showing itself. Anyway, it's very easy to make a new one - here's the walkthru I posted: http://legacygt.com/forums/showpost.php?p=379369&postcount=381 [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
fatbastard Posted November 7, 2006 Author Share Posted November 7, 2006 Thanks...I found the info later...I am just surprised it is crapping out already. I think I got the set up in June so I would have expected it to be a bit more durable. But I guess there just may have been a defect in the disc from the get go. If it turns out to be anything else I will let you all know. Link to comment Share on other sites More sharing options...
