edkwon Posted October 19, 2006 Share Posted October 19, 2006 I rememebr when i had my WRX there was a plug located right below the boost solenoid cover that you simply had to unplug and the DRLs would be disabled however the rest of the lighting was fully functional, anyone know of a similar trick under the legacy hood? Ed Link to comment Share on other sites More sharing options...
mvigneau Posted October 19, 2006 Share Posted October 19, 2006 It is not that easy on an '07. If you unplug either of those cables, it doesn't just disable the DRL's... You will actually have to cut/splice in order to do it. No one has posted a walkthrough as of yet (but you could be the first ) No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
Jimbizzle Posted October 19, 2006 Share Posted October 19, 2006 http://www.legacygt.com/forums/showthread.php?t=42292&highlight=drl Link to comment Share on other sites More sharing options...
