canis Posted October 17, 2006 Share Posted October 17, 2006 My girlfriend has a 2002 Audi A4, 1.8 turbo, not quattro, 5-speed. She had the transmission replaced one year ago (extended warranty). She had the clutch replaced two weeks ago ($1,200 &$%^& ). When you push in the clutch quickly (or let it out quickly), mostly in first gear and partially in second gear, there is a loud POP! sound and you can feel a thump through the car. If you're gentle and slip the clutch, no pop. So basically it's when there's a significant and sudden change in the torque on the driveline. It's a hydraulic clutch, so it's not the clutch linkage. I just replaced the motor mounts ($300 *^%$#@#$%^), so it's not those. What else could it be? Tranny mount? I don't know if it did it before the transmission was replaced, so I can't say if the shop caused it. Link to comment Share on other sites More sharing options...
Jedi Pimp Posted October 17, 2006 Share Posted October 17, 2006 Sounds like an issue with the clutch replacement and the release bearing. Link to comment Share on other sites More sharing options...
