SMOO13 Posted October 11, 2006 Share Posted October 11, 2006 http://www.scoobytuner.com/images.sized/1468.jpg Cobb Impreza Equal Length Header Cobb's much anticipated Equal Length header is now available and designed to replace the factory exhaust system starting from the head and ending where the factory second catalytic converter normally would. Cobb spent an enormous amount of time, effort and money building their header and we have well over 200 dyno passes that we've made developing it. The end result is a header that outperforms with others -- featuring equal length construction and an optional high-tech metallic substrate catalytic converter tested to flow virtually as well as a straight pipe! Would this header which was designed for the impreza rs fit on a 2006 2.5i? Link to comment Share on other sites More sharing options...
AWDxBOOST Posted October 11, 2006 Share Posted October 11, 2006 my guess is yes with some fudging around, but id ask codd bc that midpipe doesnt look like itd work Link to comment Share on other sites More sharing options...
