taskforcefreddy Posted October 8, 2006 Share Posted October 8, 2006 So I just installed a new UP and DP and have an exhaust leak somewhere. My first impression was somewhere between the manifold and the turbo but when the car is in full boost, you can hear a whistling noise telling me it's probably coming from the DP. After about 5-10 minutes, the car and all the components warm up and it goes away and it almost seems as though it loses about a half a step on take-offs making me think that it must be on the DP side. If it were on the UP side of things, wouldn't it be losing boost if there was a leak? I've done some searching but haven't had any luck. Please advise. Link to comment Share on other sites More sharing options...
GTsleeper2 Posted October 8, 2006 Share Posted October 8, 2006 sure its not the turbo(noise) itself? it would have to be a HUGE leak to 'lose' boost, & still u wont really lose it u just wont gain the same, because tu much exhaust is leaking instead of spinning the turbo to generate boost. go though a couple warm -ups & cool downs & retighten all nuts/bolts. main leaks people have had were at the maifold to uppipe. also at the dp to exhaust connection hope that helps Link to comment Share on other sites More sharing options...
taskforcefreddy Posted October 8, 2006 Author Share Posted October 8, 2006 Thanks man. I agree that it's probably the turbo making the noise leading me to believe it's coming after the turbo, i.e torbo to DP. I thought it would be the manifold to UP leak as well but this whistling noise is throwing me off but will recheck that again. As far as the DP-exhaust... don't think this is the case because it's definately coming from the front side of the car. Thanks again. Link to comment Share on other sites More sharing options...
GTsleeper2 Posted October 8, 2006 Share Posted October 8, 2006 cool, mine was the same way. love that noise!! if im not mistaken its more of a 'whoosh' noise if leaks. also usually only in boost situations Link to comment Share on other sites More sharing options...
taskforcefreddy Posted October 8, 2006 Author Share Posted October 8, 2006 Oh yeah, one other thing I forgot to mention. When I opened everything up, I found one of the nuts missing on the top of the stock DP where it connects to the turbo. All the other bolts came lose fairly easy as well. I replaced it with a nut that connected the 2 portions of the stock DP together. Should I be concerned? Link to comment Share on other sites More sharing options...
