derkahn Posted October 5, 2006 Share Posted October 5, 2006 Has anyone tried to install a whiteline anti lift kit in an 05 or newer legacy gt or outback? Whiteline said that new legacy suspension has different geometry and may not work correctly. can I just add more spacers to make up for subframe differences? thanks, Link to comment Share on other sites More sharing options...
jerami1981 Posted October 5, 2006 Share Posted October 5, 2006 are you trying to lift it? Link to comment Share on other sites More sharing options...
captainmorgan Posted October 5, 2006 Share Posted October 5, 2006 I think you misunderstand what an ALK is for. Its is to add a bit more caster and to stiffen the control arm up to reduce the amount of front dive/lift during braking and acceleration. Also Legacy's use totally different setups and Whiteline does not make a solution for Legacy's at this time. Link to comment Share on other sites More sharing options...
derkahn Posted October 5, 2006 Author Share Posted October 5, 2006 thanks I know what the alk is for I am not trying to lift it I was told that among some other things the subframe height, depth, thickness is different Link to comment Share on other sites More sharing options...
captainmorgan Posted October 5, 2006 Share Posted October 5, 2006 Its a completely different chassis. Nothing is the same. Link to comment Share on other sites More sharing options...
driggity Posted October 5, 2006 Share Posted October 5, 2006 Its a completely different chassis. Nothing is the same. Yep. The biggest obstacle is the fact that the rear of the control arm attaches to the chassis in a completely different way on the Legacy vs the Impreza. Link to comment Share on other sites More sharing options...
captainmorgan Posted October 5, 2006 Share Posted October 5, 2006 Of which, I think the Legacy gets shafted. The Impreza suspension design is so much better in so many ways I can't even start. Link to comment Share on other sites More sharing options...
