NateFK Posted September 22, 2006 Share Posted September 22, 2006 Maybe I'm just seeing things but I need another opinion. A while back noticed that after fill up my tank with gas I get great gas milage for the first 100 or so miles. then all of a sudden it goes down about 10 miles. I've tried almost everything. tired filling the tanks part away, thinking maybe it was so full the gas guage couldn't measure correctly, same thing. tried commuting 90% of time by highway, samething. tried city same thing. tried gunning it for the first 100 then changing to casual. minor improvment at best but still the same result. even filled it up with premium then later on fuel cleaner. minor results but still bad. anything else I should try? I mean I can live with it fine but if it's not me then what is it? Link to comment Share on other sites More sharing options...
rottenspam Posted September 23, 2006 Share Posted September 23, 2006 What is you gas millage for the first 100 miles, and what is it after the first 100 miles? How are you measuring the fuel millage? Link to comment Share on other sites More sharing options...
Scotty Posted September 23, 2006 Share Posted September 23, 2006 Since it's a 98, when's the last time it has been serviced? Link to comment Share on other sites More sharing options...
NateFK Posted September 23, 2006 Author Share Posted September 23, 2006 Well to answer rotten's question I'm getting about 22 - 25 miles per gallon give or take. then drops to almost 15 - 17 give or take. My friend hooked up a digital gas gauge thatr showed precentage. like the ones at http://www.dakotadigital.com and it pretty much backed up the reading on the gas needle. To answer Scotty's question it as recently service about a month ago. It's under 100,000 miles. again it might be me but just a second or third opinion. Link to comment Share on other sites More sharing options...
tytek Posted September 24, 2006 Share Posted September 24, 2006 that is low MPG for a NA engine... let us know what the culprit was when you find it Link to comment Share on other sites More sharing options...
Vimy101 Posted September 24, 2006 Share Posted September 24, 2006 Your problem could lie in the MAF sensor or thermostat among other things. At least those are a couple of things you could check. What is your average mileage per tank? Link to comment Share on other sites More sharing options...
NateFK Posted September 24, 2006 Author Share Posted September 24, 2006 Um about 225 - 230. if I run it to near dry. Link to comment Share on other sites More sharing options...
