kosherpineapple Posted September 16, 2006 Share Posted September 16, 2006 So im driving along normally and my intake sounds perfectly fine no weird noises or anything, when i decided to go fully throtle i hear the deep tone come out still normal!! with the sucking in of air which i can hear... now once im at full throtle i get to about 4 thousand rpms and it sounds like the air is fluttering like there is eiither to much air or its recirculating something like that... if anyone is having the same problem please let me know how to fix it.. thank you DR Link to comment Share on other sites More sharing options...
kscottw Posted October 10, 2006 Share Posted October 10, 2006 I installed mine about a week ago and i have the same problem. I dont think that it is any thing we did wrong for for that matter....i heard that it doesnt need to be tuned either. From what i understand, it makes that sound for some reason. Link to comment Share on other sites More sharing options...
GTTuner Posted October 11, 2006 Share Posted October 11, 2006 Get used to it. Most of the short ram systems make some hedious sounds. I removed my K&N Typhoon because I couldn't stand the noise anymore. Link to comment Share on other sites More sharing options...
waverunner Posted October 12, 2006 Share Posted October 12, 2006 wastegate flutter! Link to comment Share on other sites More sharing options...
TSiWRX Posted October 16, 2006 Share Posted October 16, 2006 Er......did you totally forget what I'd written to you just a week or so ago (from the date of the originating post) ? http://www.legacygt.com/forums/showthread.php?t=42751&highlight=kosher Why don't people listen to me? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
GTTuner Posted October 16, 2006 Share Posted October 16, 2006 wastegate flutter! AND turbo hiss at partial blow off. I data logged both set ups, stock A/B with OE element, and My K&N. THey flow identical amounts of air! Link to comment Share on other sites More sharing options...
j255c Posted October 16, 2006 Share Posted October 16, 2006 why do most tuners not like perrin short ram's... it seems to be the same as a k&n intake 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
TSiWRX Posted October 17, 2006 Share Posted October 17, 2006 ^ It's a little less stable in how it presents its lean plateaus - you'll want the Perrin Short Ram to be tuned by a tuner who has had extensive experience with this product. Also, it's best done via a live tune or via remote "e-tunes," instead of an off-the-shelf map (although there are tuners out there who have excellent off-the-shelf maps based on this component, so this latter criteria isn't a locked-in definite). The intake cone design as well as proximity of the MAF housing both contribute - it's speculated - to a bit of turbulence, thus causing the difficulties. From what's known through various postings here, the Typhoon seems to not cause this issue on our LGTs (even though it does, at the same time, present this very problem on other vehicle models). As such, it's currently the "preferred short-ram" of the community. The other main concern is that the Perrin is not heat-shielded, and if you have the ability to log or otherwise visualize IATs, you'll see how fast this shoots up. To be fair, though, the Typhoon's heat-shield is not a "sealing" component, either - and that's less-than ideal in and of itself, as even with a home-made, laboratory-grade thermoplastic and two-layer ThermoTec heat-barrier'ed heat-shield installed - *_SEALED_* - I still saw temperatures in this area climb decently rapidly. All said and done, for "Stage II" applications, properly tuned, the Perrin Short Ram will reap benefits that are identical to any of the other marketed "short ram" intakes - to the tune of appx. 5 to 15 wHP (dyno dependent). <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
pepe Posted November 7, 2006 Share Posted November 7, 2006 I wish I had checked out this earlier, put mine on tonight and can't stand it...sounds like crap all that fluttering and noise. Putting the stock box with perrin drop in tomorrow. Link to comment Share on other sites More sharing options...
