Kaixen 6000K Installed
legacy4me
I met up with the specialists today and they are going to install the lights on Wednesday. They talked about a relay for the DRL's, but they informed me that I should dissable DRL's first. I know there is a write up on DRL's already, are they easy to disable. I will post updates once I get the lights installed.
Yes very easy.....here...follow these directions, and yes you should dissable your DRL's before you install your HID's.
http://legacygt.com/forums/showthread.php?t=2117&highlight=drl+disable
I just disabled the DRL's. IT was easier than I thought. I hope I did everything correctly. Once I unscrewed the two side screws, I pulled down on the cover and it popped off. Once I took off the cover I saw alot of plugs, I kept thinking of the picture from the above link, and then saw in the top left corner, a green sticker that said something like SUBARU DRL. and I unplugged that, tried to put it in a spot that wouldnt rattle hopefully. Checked to make sure they were disabled. Screwed the cover on, and I was all set. I also compared the car to our IS 300's HID's. My Silverstars in my Legacy look bright while on road, but not when compared side by side real HID's. I forgot to take pics of this comparison with silverstars, but will take some before my HID's are installed.
^ If you want your light to be as useful as that on your Lexus (which, as a factory HID system, should come in at between 4300 to 4600K), you'll want to stick to about 5000K or lower color-temperature.
6000K pushes into the blue range - while it may appear to give off that cool-blue "HID look," their performance will be somewhat sub-optimal/compromised, particularly during inclimate weather conditions. You will also tend to think that you're "seeing farther" as the bluish tint of the light will tend to highlight street-signs, but this is purely an illusion which can even be achieved with the dreaded "blue bulbs."
If this is the dealer/shop that you referred to in this thread:
http://www.legacygt.com/forums/showthread.php?t=42418
Then, honestly, you're truly *NOT* getting a system that's any more "OEM" than any other simple plug-and-play kit.
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
^ Correct. :)
But, bro, you're one order of magnitude off..... 4,300K, not 43,000K ;) I know it was a typo, but still, thought it was funny! :lol:
If you live in a brightly-lit city atmosphere, legacy4me, you might actually feel that the 6000K setup is very acceptable - or even preferable - as it should provide some contrast on-road with ambient street lighting, as well as serve to highlight signage. And if you have reflectors buried in the road-surface, you may not notice much compromise at all in inclimate weather.
^ Correct. :)
Yeah sorry I meant the 4,300K. The dealer told me that 6,000k is the lowest temp of all their kits. and thats its the most whitest and clearest. I know about all the other temps, but from all the pics and info I've gotten, the 6,000k seems just like the 4,300 - 5,000 other kits. I will know after they are installed I guess. I will post pics too.
Kit was installed today, only took 30 mins! I got a discounted price since I had already disabled the DRL's and no relay was needed. The install looks very clean, cant even tell the ballasts are there until you search for them. There was a little trouble however. Once I first drove off the lot, my "check engine light" was on, and the green "cruise" button was blinking. I took the car back, they turned it off for about 30 seconds, turned it back on, and the warning lights were no more. I will keep an eye and see if anything looks fishy. The lights look so good. They dont look at purple as I thought they would. It's not night yet, so I will really know what they look like in a few hours. I beleive they need to still burn in though, they have a nice cut off, with like a yellowish line at the top. I dont have any complaints yet. I will keep you posted with this kit.
