Cruusher Posted September 5, 2006 Share Posted September 5, 2006 I have this 92 Legacy GL 4-door wagon. Used to be, as soon as the key was in and turned on, there was an immediate connection and it started fine. Now as soon as I turn the key to start, there is a delay for a few seconds before the starter kicks in and turns the engine over. All good connections to battery are good. Something about tapping on the starter itself seems to correct the problem. I just hope it's not some other electronic device. ..any comments? Thank you, Cruusher Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 10, 2006 Share Posted September 10, 2006 New ignition coil perhaps? Link to comment Share on other sites More sharing options...
LetItSnow Posted September 11, 2006 Share Posted September 11, 2006 I don't think that would delay the starter's spinning? Link to comment Share on other sites More sharing options...
I3eXa Posted September 11, 2006 Share Posted September 11, 2006 well if tapping on the starter seems to help, try replacing the starter and seeing if that works. Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 11, 2006 Share Posted September 11, 2006 The reason why I suggested a new ignition coil was that was the issue with my boat starter. Tapping helped. The brushes inside needed to be taken apart and cleaned, but it was just as cheap to get a new coil. Link to comment Share on other sites More sharing options...
dplacen Posted September 13, 2006 Share Posted September 13, 2006 Sounds like you need a new starter. Link to comment Share on other sites More sharing options...
Cruusher Posted September 13, 2006 Author Share Posted September 13, 2006 It's probably the starter motor. Now on top of this, wife was driving in town 2 days ago when she turned a corner and it just died. Sounds like a Timing Belt. Thankful that this 2.2 engine is non- interference. Timing belt should be easy. All you have to do is set the crank....then line-up the cam gears. If this were my 77 Ford, I could diagnose anything immediately with easier access...lol Link to comment Share on other sites More sharing options...
dplacen Posted September 13, 2006 Share Posted September 13, 2006 The timing belt on a 2.2 should be changed every 60K. Are you certain it's the timing belt. Link to comment Share on other sites More sharing options...
LetItSnow Posted September 13, 2006 Share Posted September 13, 2006 The reason why I suggested a new ignition coil was that was the issue with my boat starter. Tapping helped. The brushes inside needed to be taken apart and cleaned, but it was just as cheap to get a new coil. I'm intrigued; what does the operation of the starter motor have to do with the ignition coil? Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 13, 2006 Share Posted September 13, 2006 I'm intrigued; what does the operation of the starter motor have to do with the ignition coil? Dunno, but starts beautifully now. Link to comment Share on other sites More sharing options...
