atouk Posted August 31, 2006 Share Posted August 31, 2006 I have been getting some slight noise and vibration during breaking at high speed. I have a 06 LGT sedan with about 1500 miles on it. It is a soft drumming noise that comes from the front brakes and is sometimes accompanied by a slight steering wheel shake. This only happens (or is noticeable) when I’m breaking at highway speeds. Cars I’ve had in the past that got similar symptoms ended up having warped rotors, but this was always towards the end of the rotor’s lifetime. Could a new car have a warped rotor already? Could it be something else, like a pad problem? Any ideas before I schedule service to check this out? Thanks! Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2006 Share Posted August 31, 2006 you probably have brake deposits on your rotors.. Keefe Link to comment Share on other sites More sharing options...
atouk Posted August 31, 2006 Author Share Posted August 31, 2006 ^^ Is this normal for new brakes? Is it something to worry about? Link to comment Share on other sites More sharing options...
forestir Posted August 31, 2006 Share Posted August 31, 2006 You probably want to read this... http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml Link to comment Share on other sites More sharing options...
atouk Posted August 31, 2006 Author Share Posted August 31, 2006 You probably want to read this... http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml Wow, I had no idea. Thanks for the article, that's really good information to know. Link to comment Share on other sites More sharing options...
Boosted Posted August 31, 2006 Share Posted August 31, 2006 I had the same problem. I took the car to the dealer and they resurfaced my rotors and the problem is gone (for free). They said it was from deposits on my rotors... i.e. from using the parking break, etc. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 31, 2006 Share Posted August 31, 2006 I had the same problem. I took the car to the dealer and they resurfaced my rotors and the problem is gone (for free). They said it was from deposits on my rotors... i.e. from using the parking break, etc. Huhn? I thought the LGT used a drum parking brake. Why would that affect the disc part? Link to comment Share on other sites More sharing options...
Spec B Posted August 31, 2006 Share Posted August 31, 2006 I had a similar problem on my old IS300..and it turned out to be a bent inner lip on my rim..The dealer missed it when I took it in. I got the rotors replaced but the problem remained. I would check the wheels first..I think it is very odd to have this problem with only 1500 miles. Good luck. Link to comment Share on other sites More sharing options...
Xenonk Posted August 31, 2006 Share Posted August 31, 2006 it's just brake deposits, nothing to worry about. Nothing like a few good hard stops cant cure it. Keefe Link to comment Share on other sites More sharing options...
