motoracer Posted August 28, 2006 Share Posted August 28, 2006 new to the boards, coming from an wrx wagon stg 3 picking up a 06 LGT wagon. if anyone needs any mechanical help or question feel free to ask Link to comment Share on other sites More sharing options...
whitetiger Posted August 28, 2006 Share Posted August 28, 2006 Welcome fellow tech. Link to comment Share on other sites More sharing options...
dplacen Posted August 28, 2006 Share Posted August 28, 2006 Welcome too felow technician! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 29, 2006 Share Posted August 29, 2006 new to the boards, coming from an wrx wagon stg 3 picking up a 06 LGT wagon. if anyone needs any mechanical help or question feel free to ask I'm in Middletown- PM me some info and I can probably shoot you some business- I assume you're looking to work off the books? Link to comment Share on other sites More sharing options...
whitetiger Posted August 29, 2006 Share Posted August 29, 2006 arent we all. Link to comment Share on other sites More sharing options...
mrjoshuanyc Posted August 29, 2006 Share Posted August 29, 2006 Hey suby tech, I just ordered a couple of perrin mufflers are these easy to install. I am thinking a couple of bolts and I am in? I have 17000miles on the car so I dont think the bolts should be too bad. Thanks Link to comment Share on other sites More sharing options...
motoracer Posted August 29, 2006 Author Share Posted August 29, 2006 Hey suby tech, I just ordered a couple of perrin mufflers are these easy to install. I am thinking a couple of bolts and I am in? I have 17000miles on the car so I dont think the bolts should be too bad. Thanks you should be okay, i just removed an uppipe/turbo back off of my wrx wagon with hand tools in my garage this past weekend (53,000miles). at work i just use my air tools. spray some penetrating oil on the bolts/nuts a few minute before you start (PB Blast is the best) Link to comment Share on other sites More sharing options...
mrjoshuanyc Posted August 29, 2006 Share Posted August 29, 2006 Thanks, I keep you updated... Link to comment Share on other sites More sharing options...
Gt4Me Posted August 29, 2006 Share Posted August 29, 2006 Welcome. Quick question, my oil fill cap has been very hard to turn and remove after checking/adding etc. Is my pcv valve clogged, stuck closed? BTW I have a catch can. Thanks. Link to comment Share on other sites More sharing options...
Effin Ponderous Posted August 29, 2006 Share Posted August 29, 2006 I'm in Middletown- PM me some info and I can probably shoot you some business- I assume you're looking to work off the books? I didn't know you were in Middletown...I used to live in Scotch Town, and now in Middletown NJ Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 29, 2006 Share Posted August 29, 2006 I didn't know you were in Middletown...I used to live in Scotch Town, and now in Middletown NJ Cool- we have a property in Scotchtown. Dude, we gotta meet up sometime. Link to comment Share on other sites More sharing options...
recuomo Posted August 29, 2006 Share Posted August 29, 2006 Motoracer, care to comment on this issue? My '04 OB with 31K miles has an intermittent belt squeal and when I checked it I noticed the AC clutch pulley is covered in brown dust. My guess is the clutch material is causing the dust and maybe causing the belt to sometimes slip. The dealer insists the clutch dust is normal. The AC operation is mostly normal but on really hot humid days it seems to struggle. Thanks. Link to comment Share on other sites More sharing options...
motoracer Posted August 30, 2006 Author Share Posted August 30, 2006 Motoracer, care to comment on this issue? My '04 OB with 31K miles has an intermittent belt squeal and when I checked it I noticed the AC clutch pulley is covered in brown dust. My guess is the clutch material is causing the dust and maybe causing the belt to sometimes slip. The dealer insists the clutch dust is normal. The AC operation is mostly normal but on really hot humid days it seems to struggle. Thanks. A/C compressor should be ok, check to see how much deflection you have on your acessorie belt (how much you can push the belt in the middle between the pullies. may just need your belt tightened. your still under the 36k warranty, tell em you want your A/C checked (especially how much freon was recovered, should be right around .055kg) and to check the belt. should be of no charge. lemme know what happens. which dealership. Link to comment Share on other sites More sharing options...
motoracer Posted August 30, 2006 Author Share Posted August 30, 2006 i know alot of people don't like Bill Kolb Subaru (being a NASIOC, SQC, and now LGT member) if any of you guys have any service issues ask for me, lateef yamamoto, my service manager knows that i'm friends w/ many subie enthusiast and most likley work with you. Link to comment Share on other sites More sharing options...
BIGJon Posted August 30, 2006 Share Posted August 30, 2006 (especially how much freon was recovered, should be right around .055kg) .055kg=1.940067907 ounces...that's all this system holds? Link to comment Share on other sites More sharing options...
motoracer Posted August 30, 2006 Author Share Posted August 30, 2006 .055kg=1.940067907 ounces...that's all this system holds? yeah between .050-.060, we charge em at .055 Link to comment Share on other sites More sharing options...
BIGJon Posted August 30, 2006 Share Posted August 30, 2006 yeah between .050-.060, we charge em at .055 I haven't looked...is that 134? Link to comment Share on other sites More sharing options...
Effin Ponderous Posted August 30, 2006 Share Posted August 30, 2006 Cool- we have a property in Scotchtown. Dude, we gotta meet up sometime. Definately...I get in to OC every now and then...your only a few miles further... Link to comment Share on other sites More sharing options...
Effin Ponderous Posted August 30, 2006 Share Posted August 30, 2006 Any of the techs work near Newark and want to make a quick $25 during lunch? Link to comment Share on other sites More sharing options...
mccorry Posted August 30, 2006 Share Posted August 30, 2006 Welcome! Link to comment Share on other sites More sharing options...
motoracer Posted September 1, 2006 Author Share Posted September 1, 2006 Welcome. Quick question, my oil fill cap has been very hard to turn and remove after checking/adding etc. Is my pcv valve clogged, stuck closed? BTW I have a catch can. Thanks. try replacing your rubber gasket on your oil filler cap, i had a buddy w/ a greddy cap w/ same problem and we changed the gasket and that worked for him. lemme know if you need one Link to comment Share on other sites More sharing options...
Gt4Me Posted September 2, 2006 Share Posted September 2, 2006 Thanks, will do and let you know how it works out. Link to comment Share on other sites More sharing options...
