mikelbonin Posted August 27, 2006 Share Posted August 27, 2006 Running one second, not running the next. No warning, no symptoms, no nothing. It has no spark. I have checked the ignition coil, camshaft position sensor, and crank position sensor. They all look good. Is there any way to check the igniter (or is it ignition module?). It costs $178 and I don't won't to order it as a guess unless there is no way to check it. Also, the Chilton's manual appears to say there is no way to check codes or do any self-diagnosis on the 1996 model 2.5 liter LSi. Am I reading this right or is there a way? Thanks Link to comment Share on other sites More sharing options...
kkushner4474 Posted August 30, 2006 Share Posted August 30, 2006 I believe that any car 96 and older has odb2 and you can take that to auto zone and they will read your codes for free Sorry i jsut realized that your car does not run sorry Link to comment Share on other sites More sharing options...
jah77clash Posted August 31, 2006 Share Posted August 31, 2006 check your battery terminal connections, clean the corrosion from them. (happened twice to me) i hope its something simple for you! Link to comment Share on other sites More sharing options...
stanjk3 Posted August 31, 2006 Share Posted August 31, 2006 Our '95 Legacy has OBD II. Some '94 and '95 cars have it, '96 is the year it became mandatory. IIRC I paid ~$130 for my code reader. There's a cheaper one that just give s you the code w/o saying what it is. And there are more expensive ones that can give you real time readings. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
mikelbonin Posted August 31, 2006 Author Share Posted August 31, 2006 My new OBD II code reader was shipped this morning. Maybe that will head me down the right path. I'll let you know. Thanks for the input. Link to comment Share on other sites More sharing options...
