liquidiq Posted September 23, 2004 Share Posted September 23, 2004 Can we use the 2002+ Impreza subwoofer kit on the 2005 Legacy? They are different part numbers, but they would seem the same to me. Anyone? Just because you can get a used stock subwoofer pretty cheap off the Impreza guys ;) Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 23, 2004 Share Posted September 23, 2004 Too big, I believe. Link to comment Share on other sites More sharing options...
c_hunter Posted September 24, 2004 Share Posted September 24, 2004 I initially thought the Impreza sub was too big. In fact, I sold the one out of my 03 WRX after I could not get it under the seat of my new 05 OB XT. When I ordered the "right" sub for the 05 Leg/OB, it looked exactly the same as my old WRX sub. And it was s tight fit to wedge it under the seat, but it does fit. The only thing you get by buying the Leg/OB version of the sub is the proper bracket -- the Impreza bracket would not work. But the sub itself, and the harness, are the same. Craig Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 24, 2004 Share Posted September 24, 2004 [quote name='c_hunter']I initially thought the Impreza sub was too big. In fact, I sold the one out of my 03 WRX after I could not get it under the seat of my new 05 OB XT. When I ordered the "right" sub for the 05 Leg/OB, it looked exactly the same as my old WRX sub. And it was s tight fit to wedge it under the seat, but it does fit. The only thing you get by buying the Leg/OB version of the sub is the proper bracket -- the Impreza bracket would not work. But the sub itself, and the harness, are the same. Craig[/quote] I thought the legacy one was smaller? If not, no reason not to pick up a used WRX sub and mount it with a custom bracket. Link to comment Share on other sites More sharing options...
c_hunter Posted September 25, 2004 Share Posted September 25, 2004 Yeah, i thought so too, but the sub itself is the same! I actually sold the sub out of my WRX and then paid another $50 for a new 05 Leg/OB sub. When I opened the box I almost barfed.... Either a custom bracket, or perhaps no bracket -- if you could attach the sub to the carpet with velcro or double sided foam tape, it would probably be just as solid. Craig Link to comment Share on other sites More sharing options...
