voyetra8 Posted August 20, 2006 Share Posted August 20, 2006 Hey all, long time no post! I posted about this some time ago, but I am posting about it again because I never got a definitive answer, and I've narrowed the symptoms down a bit. Here's what's happening with my '05 5EAT LGT wagon, 15,000 miles, COBB Stage1 1. Pronounced and regular ticking sound coming from engine bay, starting at 1500 RPMs and continuing to 1900 RPMs, and then stopping abruptly. IE - "TICK TICK TICK TICK TICK" (About 3 ticks per second.) 2. The tick does not happen when the car is stationary- I can't get it to make the sound unless I am moving. 3. It does not vary in speed. 4. It happens when the car is hot and when it's cold. I plan to take it in for service next week, but I'd love to hear any possible diagnosis, if any. Thanks, David Link to comment Share on other sites More sharing options...
red beast Posted August 20, 2006 Share Posted August 20, 2006 fuel injector? Link to comment Share on other sites More sharing options...
voyetra8 Posted August 20, 2006 Author Share Posted August 20, 2006 fuel injector? Interesting, hadn't considered that. Would that explain why it only happens while moving? (IE- The engine is under load.) Maybe I could I could torque brake and see if it ticks under load when stationary.... Link to comment Share on other sites More sharing options...
red beast Posted August 20, 2006 Share Posted August 20, 2006 this question came up at a legacy meat today but, the best thought on his engine was piston slap. disconnect one injector at a time as the engine is running. Link to comment Share on other sites More sharing options...
voyetra8 Posted August 20, 2006 Author Share Posted August 20, 2006 this question came up at a legacy meat today but, the best thought on his engine was piston slap. disconnect one injector at a time as the engine is running. I can't do that, as it only happens when the car is moving..... Link to comment Share on other sites More sharing options...
red beast Posted August 20, 2006 Share Posted August 20, 2006 most everything either doesn't move or it varies in speed. did you check underneath for anything sticking on the wheels or driveshafts? grounding wire? ..i doubt Link to comment Share on other sites More sharing options...
whitetiger Posted August 21, 2006 Share Posted August 21, 2006 this question came up at a legacy meat today but, the best thought on his engine was piston slap. disconnect one injector at a time as the engine is running. learn fast dont we... and yes, he's prolly got somthing stuck on his tire if it only happens when he is moving. Link to comment Share on other sites More sharing options...
red beast Posted August 21, 2006 Share Posted August 21, 2006 learn fast dont we... my mind is like a spongebob sponge. http://www.happytoys.de/_img/artikel/theme89/450156.gif Link to comment Share on other sites More sharing options...
voyetra8 Posted August 21, 2006 Author Share Posted August 21, 2006 learn fast dont we... and yes, he's prolly got somthing stuck on his tire if it only happens when he is moving. Nah. Again- it starts at 1500 RPMs, and the suddenly stops at ~1900. It's mechanical in nature- and never changes tempo. Link to comment Share on other sites More sharing options...
whitetiger Posted August 21, 2006 Share Posted August 21, 2006 engine knock then perhaps... Link to comment Share on other sites More sharing options...
hogmeat Posted August 21, 2006 Share Posted August 21, 2006 this question came up at a legacy meat today, did somebody say meat? I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
voyetra8 Posted August 21, 2006 Author Share Posted August 21, 2006 engine knock then perhaps... I thought engine knock was basically impossible because of the ECU? Also, I thought engine knock sounds like someone throwing stones around inside the engine bay- not a repetitive ticking sound? Link to comment Share on other sites More sharing options...
Brady Posted August 21, 2006 Share Posted August 21, 2006 It sounds a LOT like piston slap. In my 02 RS I had this if the engine was under certain conditions. It was a strange sound, but "perfectly normal." It probably is changing frequency, but would be hard to distinguish or perceive the change in frequency if it's only happening between the range of 1500 and 1900 rpm. Either way, there is no harm in asking when you bring it in for service. Keep an eye (or ear as the case may be) and pay attention to any other changes. Link to comment Share on other sites More sharing options...
SubiGT Posted August 21, 2006 Share Posted August 21, 2006 There is a TSB for knocking of the timing belt tensioner bracket........ Many Shuvs and Zuuls knew what it was to be roasted in the depths of the Slor that day, I can tell you! Link to comment Share on other sites More sharing options...
