Tuned200 Posted August 12, 2006 Share Posted August 12, 2006 Basically, will WRX and STI brakes bolt up? when i search listing on websites, they show no brake upgrades for our cars, just wrx and sti. thanks, Link to comment Share on other sites More sharing options...
Xenonk Posted August 12, 2006 Share Posted August 12, 2006 use 2004 STi brake upgrades, but you have to remember, you probably need new wheels as well.. there are websites that sell 2005+ LGT BBKs out there: Prodrive Cobb Racing Brake Rotora Endless etc Keefe Link to comment Share on other sites More sharing options...
75sausage Posted August 14, 2006 Share Posted August 14, 2006 I just bolted up a Rotora 4/2 kit from my 02' WRX on my new 06' LGT. The only mod I had to do was to replace steel braid brake line with the stock one on the rear calipers. Perfect fit all around. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 15, 2006 Share Posted August 15, 2006 use 2004 STi brake upgrades, but you have to remember, you probably need new wheels as well.. ^ +1 - if you're riding on the stockers, you'll need to change-out to aftermarket rims. There's a list of both 17s and 18s ( as well as increasingly pimp sizes thereafter ) which are known to clear the OEM '04 STi Brembos on Nabisco. Also, while the fronts are true "bolt-ons," if you're interested in a rear setup to-match, you will need custom-fabricated/aftermarket brackets for that set. And like good brother Keefe said, look around, there's now quite a number of aftermarket makes of "BBKs" for the '05+ LGTs. Several of these kits even allow you to retain the stock 17s - while being even "larger" in disc diameter than the OEM Brembos ! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Xenonk Posted August 15, 2006 Share Posted August 15, 2006 ^ it's not just the overall diameter, but it's the thickness of the plates that have been proven to be the better attribute to look for in the BBK. Brother Praedet has a very well written thread on brake-bias as well, something to look at as you dont want to shift too much of the brake bias to the rear. I rather just get better pads and thicker rotors when applicable. Running brake ducts for track days is a bonus as well. Keefe Link to comment Share on other sites More sharing options...
TSiWRX Posted August 15, 2006 Share Posted August 15, 2006 ^ Roger that - I was simply mentioning "larger diameter" rotors to illustrate that it can be crammed in there, under our stock 17s, and that it's not necessarily a limiting factor. Nothing to do with "performance" at all. Just purely a "size" thing. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Mach V Dan Posted August 15, 2006 Share Posted August 15, 2006 Also, while the fronts are true "bolt-ons," if you're interested in a rear setup to-match, you will need custom-fabricated/aftermarket brackets for that set. The rear Brembo/STi upgrade we sell requires no custom parts; it's a bolt-on solution, as is the front. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
sgt Posted August 15, 2006 Share Posted August 15, 2006 Too bad you cant get the rear brackets separately Link to comment Share on other sites More sharing options...
Mach V Dan Posted August 15, 2006 Share Posted August 15, 2006 Too bad you cant get the rear brackets separately Working on that. Remember that even with the brackets, you'll need the special rotors. The STi rotors will not bolt up. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
sgt Posted August 15, 2006 Share Posted August 15, 2006 Still though, easier to fix the ebrake issue than the caliper bracket issue Link to comment Share on other sites More sharing options...
TSiWRX Posted August 16, 2006 Share Posted August 16, 2006 The rear Brembo/STi upgrade we sell requires no custom parts; it's a bolt-on solution, as is the front. --Dan Mach V FastWRX.com ^ Thanks for the correction, Dan! Noted! I should have said that the rear OEM Brembo TAKE-OFFs from private sellers aren't "bolt ons," but that there are noted and trusted Vendors here ( yes, I used to come to you guys all the time in my DSM days! ) who market kits that do! Apologies for the confusion! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Tuned200 Posted August 17, 2006 Author Share Posted August 17, 2006 good info, thanks to all Link to comment Share on other sites More sharing options...
praedet Posted August 17, 2006 Share Posted August 17, 2006 Why get a BBK? Link to comment Share on other sites More sharing options...
TSiWRX Posted August 18, 2006 Share Posted August 18, 2006 ^ Like me, for the bling, yo! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Xenonk Posted August 18, 2006 Share Posted August 18, 2006 if it's for the bling, get some Endless or Alcon brakes 8 piston or 12 piston setup with 32 or 40mm thick x 400mm diameter rotors Oh, and dual MCs too That's bling. Keefe Link to comment Share on other sites More sharing options...
TSiWRX Posted August 18, 2006 Share Posted August 18, 2006 ^ Yeah, but I've gotta balance out teh bl1ng against: (1) being able to run my stock 17" winters Plus, much more importantly: (2) my wife not castrating me. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
praedet Posted August 18, 2006 Share Posted August 18, 2006 I'm am so happy that you admit the bling Allen Ted Link to comment Share on other sites More sharing options...
TSiWRX Posted August 18, 2006 Share Posted August 18, 2006 ^ I hide nothing! Everybody dang well knows that I don't drive nearly hard enough to get any actual use out of them. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Xenonk Posted August 18, 2006 Share Posted August 18, 2006 ^ Yeah, but I've gotta balance out teh bl1ng against: (1) being able to run my stock 17" winters Plus, much more importantly: (2) my wife not castrating me. 1) stock brakes for the stock 17" 2) sell your stock 17" wheels, tires and brakes 2a) make sure your wife praise you for selling the stock 17" equipment 2b) run on a set of cheap 18" wheels for your BBKs btw, the Endless Ewig BBKs cost around $16,000 to $17,000 for a Hummer H3 or BMW 745iL Keefe Link to comment Share on other sites More sharing options...
TSiWRX Posted August 21, 2006 Share Posted August 21, 2006 1) stock brakes for the stock 17" 2) sell your stock 17" wheels, tires and brakes 2a) make sure your wife praise you for selling the stock 17" equipment 2b) run on a set of cheap 18" wheels for your BBKs btw, the Endless Ewig BBKs cost around $16,000 to $17,000 for a Hummer H3 or BMW 745iL ^ to the Endless Ewig.... As for your "route?" That's way too much work, my friend! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Xenonk Posted August 21, 2006 Share Posted August 21, 2006 I would need a dual master cylinder to run puppies like those.. you can certainly get a 2-piece rotor to fix that problem for the bolt pattern. As for the brake caliper, I have a shop that can probably just make the adapter for it easily. the HARD part would be finding a way to come up with $17,000+ to spend like that leisurely it's not that bad to sell off your old stuff and replace it with the better new stuff Keefe Link to comment Share on other sites More sharing options...
