Elkboy Posted February 24, 2004 Share Posted February 24, 2004 I have a '90 Legacy and i was wanting to do some performance upgrades to the motor and was wondering what i could do to it. Intake, Exhaust, Cams, Injectors, Turbo, etc.. Link to comment Share on other sites More sharing options...
SUBE555 Posted February 24, 2004 Share Posted February 24, 2004 Well, you probably have the old EJ22. Borla made a header, and you could use virtually any Legacy 2.25" exhaust, not sure on the intake side. However, you really aren't going to gain much. My advice, save up for a later GT w/ 2.5L (97+) or get a used WRX. I'm not really sure what your budget is, but I'd say just stick with handling mods, they'll be more rewarding in that car, otherwise, you'd have to stick a good chunk of change in to get any sizable results. Link to comment Share on other sites More sharing options...
evolutionmovement Posted February 25, 2004 Share Posted February 25, 2004 Junk Yard EJ22 turbo - original engine for the first generation turbo Legacy. I have a 90 wagon and have one of these engines in the kitchen waiting to go in. You can get these for as low as $500. Mine's got 86k mi and is brand new inside - crosshatching on cylinders, no wear to valve train, etc. These engines are much better than the WRX engine. It is closed deck and larger displacement. Rods and crank are forged steel and even the cast pistons are of good quality. The block was designed for 400+ HP from pre-300 HP restricted WRC days. They stopped building this type of block due to expense around 1996. Early Imprezas and overseas Legacy/Liberty used 2.0 liter 4-cam versions of this motor (USDM is only SOHC, but at least its non-interference). It would probably be cheaper than a whole new exhaust and an intake of questionable value for the N/A motor. Steve Link to comment Share on other sites More sharing options...
SUBE555 Posted February 25, 2004 Share Posted February 25, 2004 As long as you get the whole wiring setup, ECU and such, should be alright. As EVO mentioned you can pick the up for cheap, just make sure you have all the parts if you do it. Otherwise it could turn out to be a nightmare. Link to comment Share on other sites More sharing options...
evolutionmovement Posted February 25, 2004 Share Posted February 25, 2004 Wiring is not an issue. Usually at the JY, you get the throttle body to turbo (or with turbo in my case). This will more than likely have the fuel lines and wiring harness with it. You would want to get the turbo ECU, though, or go stand-alone. There are only two wires from the N/A harness that can be switched at the ECU. You will also need a fuel pump of higher capacity, either turbo, WRX, or some other aftermarket although I think the WRX pump operates at variable pressure unlike the Legacy turbos - I don't know if that's a problem or not. It's about the easiest swap to do. I'm doing mine and getting an AWIC so it looks like a regular L wagon with some cheap alloy rims... SCC did a swap a WRX drivetrain article, but completely ignored this engine. Good, we can save them for the Legacies and let the ricers get shown our taillights. :twisted: Search bbs.legacycentral.org for plenty of write ups on these swaps. Steve Link to comment Share on other sites More sharing options...
SUBE555 Posted February 25, 2004 Share Posted February 25, 2004 I think the reason SCC ignored this swap is because so few of them are out there to swap, and secondly, few know of it as it initially makes less power than the WRX. It's been mentioned though in their mags in at least a couple articles IIRC. Link to comment Share on other sites More sharing options...
warlord Posted March 5, 2004 Share Posted March 5, 2004 intercool it, and more boost. thats a great first step. then exhaust and intake. then bigger injectors fuel pump and standalone computer Link to comment Share on other sites More sharing options...
SUBE555 Posted March 5, 2004 Share Posted March 5, 2004 Not recommended for the EJ22 NA motor. Link to comment Share on other sites More sharing options...
Blue98leg Posted July 25, 2004 Share Posted July 25, 2004 im sure i could find my answer in a seach or sould probally make a new post but would the EJ22T bolt right up to the tranny in a 98 leg with a EJ22 Link to comment Share on other sites More sharing options...
evolutionmovement Posted July 25, 2004 Share Posted July 25, 2004 Yes, but the clutch will need to be replaced and the transmission is a little weak if you're running real boost. Steve Link to comment Share on other sites More sharing options...
Blue98leg Posted July 27, 2004 Share Posted July 27, 2004 What tranny do u suggest? Link to comment Share on other sites More sharing options...
evolutionmovement Posted July 27, 2004 Share Posted July 27, 2004 Anything stronger would be hydraulic clutch, so you'd have to upgrade to that, but WRX transmissions are cheap. Make sure you get a matching rear end if you don't have a 3.545, though. There are import transmissions, too. Legacy turbos are hard to get. The majority seem to have been autos, but they have a 3.9 FD. Steve Link to comment Share on other sites More sharing options...
Bodhisativa Posted January 3, 2005 Share Posted January 3, 2005 Piss on it,... I got a great deal on a Firebird... :) PIMPED! Link to comment Share on other sites More sharing options...
