lucas569 Posted August 2, 2006 Share Posted August 2, 2006 anyone know of a diagram i can find on the net? i have the prosport 52mm boost gauge, I have the vac hose in,cubby out. im tapping the light inside the cubby (yellow/black stripe = ground/ blue = parking lamp???) i just need to know which one is ACC of the trip meter, i hope to use red during the daytime and white at night... Link to comment Share on other sites More sharing options...
CasopoliS Posted August 2, 2006 Share Posted August 2, 2006 anyone know of a diagram i can find on the net? i have the prosport 52mm boost gauge, I have the vac hose in,cubby out. im tapping the light inside the cubby (yellow/black stripe = ground/ blue = parking lamp???) i just need to know which one is ACC of the trip meter, i hope to use red during the daytime and white at night... red will be hard to see during the day, and white might be too bright at night. I think somewhere I posted which wire is which.... but don't have the time to search. I got ground from the dome light (I took apart the brown thing and soldered right to the board). I got Illum. and ACC from the trip computer bundle. Link to comment Share on other sites More sharing options...
CasopoliS Posted August 2, 2006 Share Posted August 2, 2006 maybe some help http://legacygt.com/forums/639436-post6.html Link to comment Share on other sites More sharing options...
lucas569 Posted August 2, 2006 Author Share Posted August 2, 2006 ya guess ill have to buy a test lamp, thats the easy part... im going nuts trying to route the vac hose... i found the grommet behind the ic but after slipping in like 5ft of hose i could not feel anything behind the dash! arrrrgggggg Link to comment Share on other sites More sharing options...
CasopoliS Posted August 3, 2006 Share Posted August 3, 2006 I used the grommet behind the driver side front fender. easy to get to from both sides Link to comment Share on other sites More sharing options...
lucas569 Posted August 3, 2006 Author Share Posted August 3, 2006 yuppers, after my extensive searches that seems to be the spot... thanks for the help btw! Link to comment Share on other sites More sharing options...
spyguy Posted August 29, 2008 Share Posted August 29, 2008 maybe some help http://legacygt.com/forums/639436-post6.html site not found...is the link correct? Link to comment Share on other sites More sharing options...
